How to Clean Synthetic Fabric Upholstery?
Boris_yo
Hi. I wiped my office chair with damp cloth that I soaked in dish detergent soap's foam. Let it dry and wiped with damp cloth that I soaked in lemon juice and wrung after.
My office chair looks better but it still has remains of stain. Any idea what other home-made stuff can clean it?
Jonnycat99
Spray on a hot solution of unscented laundry detergent, scrub it, then pull out the liquid with a shop vac. Repeat a couple times with water to rinse.
Mchart
Only real way you're going to remove that stain from a porous material like that is steam cleaning.
Boris_yo
What if I mix baking soda, citric powder in a cup of water so thick paste is formed, then spread it on chair and rub in with soft cloth, leave for 12 hours and then clean it off?
