WickedWeasel
- Jul 13, 2004
The Antec Solo case has a 120mm exhaust fan in the rear and an option for 2 92mm fans in the front. If the 120mm fan is connected to the Gigabyte DS3 motheboard fan connector, will the fan speed be automatically controlled by the motherboard? If that is possible, then where will the 92mm fans in the front be connected to so they are in sync with the rear fan? The speeds don't have to match exactly, but when the temps rise, I just want the front fans to speed up when the rear fan speeds up.
Does anyone splice the wires together so all 3 fans are running in sync?
