Chunkylover21
- Apr 8, 2006
Hey guys I have had Danger Den products cooling my CPU for the last year or 2 and its been working great. I now want to add a block to my 8800 Ultra as well. I ordered the Zalman ZM-GWB8800 block from newegg.
Right now cooling my CPU are these
Black Ice pro 120mm Radiator
D5 Pump
3/4" OD 1/2" ID Tygon Tubing
I have it rigged in a very simplistic fashion with a T Line + fillport for filling.
My question is should I simply upgrade my radiator to a 240mm Black Ice Pro II? Or should I put it on a completely seperate loop with another 120mm radiator?
Also is the block I bought a good choice? I know the fittings on it are small as hell but if I get adapters will that be ok or should I be cancelling my order for a different block?
Thanks in advance.
D5 Pump
Thanks in advance.
