How outdated is my 7800 GTX.
Boardin087
I have an XFX 7800 GTX. no particular reason why as I'm not upgrading but building a new PC at the end of this summer. But are the 150-250 dollar cards THAT much of an upgrade?
Yes, the 8800GTX 512 would be a huge upgrade performance wise. If you need that much more for the games you play, you could turn up your resolution, maybe even AA depending in the resolution you game at etc..
Yes. Yes they are.
The $150 9600GT, $180 8800GT, and $210 8800GTS 512MB are major upgrades from the 7800GTX.
hrmmmm maybe ill buy a 8800 GTS 512mb now and just put it in my new system when i buy it in 3 months :) and then just swap my 7800GTX back in. Or do you think a significant price drop/etc will occur in 2-3 months
yea saw something about cards next month?
Should i jsut go and get the 880 GTS512mb from XFX (i like the company). If so I'll likely get it like......... TOMORROW and game with it all summer :)
Vidcards are the fastest depreciating component in a gaming pc. So, unless your current card cant play a particular game you want to play at certain settings to your liking, keep your card. When you can no longer play the games you want at the settings you like, upgrade.
