mollocampo
- Nov 9, 2011
Hello everybody
I want to build a ZFS storage and VM system using Sandy Bridge but I cannot decide on a CPU+Motherboard combination (also not sure what OS to use).
My goals are:
- Media files server (NAS)
- iTunes server
- Time Machine server
- UPNP server (for Xbox360)
- Host an Ubuntu dev server VM, probably with VirtualBox
- Host other VMs for testing purposes
- Use as low power as possible when idle (maybe also with idle VM)
- I would often have 2 VMs running simultaneously, sometimes 3.
I already have:
- 5 WD 2TB Green drives
- Supermicro AOC-SAT2-MV8 8 port Sata controller
- OCZ Vertex2 120GB SSD
- Corsair 520w psu
- Huge Lian-Li case
- DVD burner
- 1920x1200 monitor
I plan to use the integrated GPU (not a gamer).
I would use the 5 2TB HDD for a raidz1 array and the SSD for the OS.
My plan is to use Napp-it for the NAS-ZFS part, VirtualBox for VMs. For the host OS, either OpenIndiana, Solaris or SolarisExpress (no experience with these).
I want to buy 16 GB of ram, enough for ZFS to breathe and for the VMs.
For the CPU, would an i3-2100 be enough? Or should I go with i5?
For the motherboard, should I go with the Z68 chipset, does it matter?
Thanks
Eric
My goals are:
- iTunes server
I already have:
- Corsair 520w psu
- Huge Lian-Li case
- DVD burner
- 1920x1200 monitor
Thanks
Eric
