How much of a difference.....
gregnash
....will I see if i change the ram, processor and motherboard from what I have in my sig to:
Asrock DualSata2
AMD 64 3000+
G.Skill PC3200 1gb stick
If I change those three items but leave the 9500pro in there for a time being will I see an upgrade in performance at all or should I just save for the card while Im at it
Thanks in advance
Unless you're doing like graphics work, then wait 'til you can do better, including the video card.
Just doing normal everyday stuff and playing WoW...
Why would I not what the dualie or the ram, the proc I can understand but from what I am going from I assume it will be a performance gain no matter what?
well the way I see it right now the amount of ram I have and the processor are the main bottlenecks for my system. The 9500pro was (and still is) a great card. So how will I need "see the performance gains I need?"
Please explain your thought process
You'll see a significant performance gain in things, just not a lot in games.
ah ok .... so if I do get it and use my 9500pro dont expect much till I get a PCI-E card is what you are trying to say
bingo
Or you could save your money until you can get it all at once because your money will go further at that point. But hey, since you're just rejecting my opinion, it sounds like you've already made up your mind and you didn't need to post about it.
Pretty much. I would save up untill you can afford more.
Don't beat a dead horse... unless you're into that kind of thing
