How much memory will an AMD board use?
narsbars
I have an AM2+ 780g chipset board, 4 mem slots. How much memory will this board run using 2 gig sticks? Will it all run in true DDR?
This will of course be in a 64 bit OS.
With 2GB sticks you'll get 8GB. All 4 sticks should work fine. Not sure what you mean by true DDR, but it will run in dual channel.
Some sites claim it is common knowledge that AMD boards will only use 1 stick per channel. Can get confusing if you haven't built a system in a few years.
This is the place to go. Thanks for the clue in.
Think that had something to do with an am2+ combined with ddr2 1200 memory or something like that. But you shouldn't have a problem with your 4 sticks.
The only problem would be the RAM would run at a lower frequency. Automatic mode in the BIOS will take care of setting the AMD recommended all slot populated frequency.
Sorry about the lack of info. Just put a 940 BE in the same board, but the temps at idle are lousy, 43C and a few minutes of Prime 95 they start hitting 59C.
I don't know if the above belongs here but if it is ok with the moderators I will ask about the Zalman 9500 I have and why the temps are so poor. Fan faces towards the exhaust fan, full speed at all times. Maybe bad thermal compound application?
Back to the memory question. So with a 64bit OS and DDR800 I should have no problems at 8 gig?
Biostar Tforce 780G M2+ HP
P.S Cheap case, but well ventilated. Three or so more posts and I can look to buy some of the stuff here you guys are advising.
narsbars
It could be a problem with the seating of the HSF. Either that or maybe your VID is high (not sure how it works with AMD CPU's).
43C at idle doesn't seem far fetched with the CNPS-9500 but, since it appears the max temp for the 940BE is 62C, you might try a re-seat of the cooler and get OCD about the paste application. A razor-blade can really help get the application even across the heat-spreader.
I take credit card offer "fake" cards and cut them into pieces and use it to spread paste. Same idea. I just had more of those lying around my house than razor blades ;).
I am going to try the paste.......again! I ran Prime 95 and the temps were heading for the high 50's after just a few minutes. I tried to be stingy with the paste, maybe a little thicker?
I see in the paste shoot out at the H that cheese didn't work either.
The other problem is that Speedfan and AMD overdrive can't agree within ten degrees C of what the temp really is. AMD claims a 32-33 C temp.
Let me ask about your zalman 9500 heatsink. Is the fan on the left or right side of the heatsink?
If it is on the left side it should be pulling air through the heatsink and exhausting it out to the exhaust fan.
But if the fan is setup to be on the right side and you turn the heatsink 180 then the exhaust fan and the zalman fan will be fighting for air.
I'm not much of the razor blade type to spread the thermal paste since it causes air bubbles frenzy.
Pea size is the way to go.
http://www.youtube.com/watch?v=ffK7L0Qj13Q
^^^ I've tried both BB size (pea is a lot of paste) and the "razor blade" method with a CC in my case. I get better temps with the razor blade method. Couple degrees better. Not a hugely significant difference though. Just more of a FWIW type of statement.
