Tim Sweeny's comments about virtual texturing (video card using system RAM for textures when the card's RAM is full):
"Virtual texturing eliminates the video memory bottleneck on texture size; whereas in DirectX 9 the size of textures we can use with full performance is limited by the amount of video memory, in DirectX 10 it is only limited by total system memory." Furthermore, Tim predicts that virtual memory will enable a "2X-4X increase in texture usage in games, which will be great for Unreal Engine 3 games, where textures are often authored at very high resolutions like 2048x2048, and then scaled down on lower-end systems to improve performance."
Now, how much of a speed difference is there between the two RAM types? Will a game that requires 600MB frame buffer run just as fast on a GTS 320 as on a GTS 640? Can we depend on Sweeney's comments and go buy a lower memory card now?
