Is RAID that much faster than just one single drive? I have a 150gb 10k Raptor X drive and it seems real fast...would adding one more make much of a difference set up in RAID? Is it worth the $200 drive?
IMO, if you do video editing and picture touchups you would see an improvment with loading large files etc. Games in general would not see any huge improvement, depends on the game, you can just watch you existing drive light to see how disk intensive your game is, mine its mainly just on level or zone changes that the HD is accessed.
The major consideration you also have to take into account is you just doubled the chance of loosing all your data if a drive failed (assuming raid 0).
So if you are experencing data bottle necks and seem to be waiting for things to load from the drive it might make the system seem snappier, but keep in mind the gotcha above.
In general unless you needed the space, the money is better spent on more ram or a cpu upgrade etc.
Tons of "should I raid 0 " in the drive section if you want more opinions.
There are a few apps that get some good use from RAID 0 but outside of video editing it's just not worthwhile IMO. Now if you want to run RAID 1 or 1+0 or 5, those are nice, especially if you have a good hardware controller, but I would spend money on a good backup system before RAID of any kind. I will say that if you want the best performance well RAID 0 would be on my list for fastest possible system but it'd behind upgrading to an 8800 GTS SLI, 4GB+ RAM, hardware soundcard, KillerNIC and pretty much everything else I can think of. But I get very annoyed with HDD crashes and data loss.
Meh, I'm not impressed with mine. I would rather have spent the money on either one big drive or on a raptor. My brothers single raptor kicks my Raid 0 7200rpm's but when loading games.
Also, windows performance as far a things working snappy, will be faster with one drive, especially a raptor. Onboard raid controllers seem to have a bit of overhead that slowes down there seeks times or somthing. This is different if you are using a raid card.
And yeah don't do it if you have no plans of backing up your important files once or twice a week.
