How much coolant ?
reaper7534!
How much ( estimated ) do I need ?
Photon 270mm Reservoir ( 690ml )
AlphaCool XT45 420mm Radiator X-Flow ( guestimating 400ml )
EVO Supremecy
Mayhem's Pastel Blue
Not doing video cards right now....that will be down the line.
I'm sure I need 2 bottles right now, just want to verify.
EVO Supremecy
I don't know how big their bottles are, but I used just over 1.5L in the following setup:
- XSPC Photon 270 D5 combo reservoir
- Alphacool Xt45 420mm rad
- Alphacool Monsta 280 rad
- EK Supremacy EVO block
- EK Fullcover GPU block
- Approx 2/3 of a box of 3/8" tubing.
This was much less than I thought I was going to need. I bought enough Ekoolant concentrate to make 3L total. Could have gotten away with 2.
For yours I'd guess you'll probably use just over 1L, but less than 2, but if they come in 1L sizes, then you have to get 2...
Yes, they are 1L size ... I could probably get away with one, but I'll do 2 to be safe.
