Deadlierchair
- Jun 12, 2003
This thread ought to be stickied in the Overclock FAQ...
Good results, well thought out and well presented.
Deadlierchair said:This thread ought to be stickied in the Overclock FAQ...
Mr. Miyagi said:I too think this thread should be stickied. It has a lot of helpful information that will help me throughout overclocking. Job well done.
This bears repeating... For the OC'er the value of low latency RAM isn't the performance gain of the lower latencies (at stock speeds or otherwise)... But the fact that these sticks were tested under higher scrutiny and thus it's highly probable that they'll reach higher speeds than the RAM which was only tested with higher (looser) timings under the same frequency.Stellar said:Great post, but as has been stated already... the true benefit from those low-latency RAM sticks is they are particularly high-yield... meaning they can be pushed to higher frequencies in an overclocked rig which will DEFINITELY benefit overall real-world performance.
This is exactly why I'm fine with running HyperX PC2700 for the time being.
Well, it depends on what's the speed gain you achieve on the processor by going from 220 to 230 (which depends on your multiplier). There's a bigger gap between 8-4-4-3 and 7-2-2-2.5 than 8-4-4-3 and 7-3-3-2.5 as well for instance.DaLurker said:So would it be more beneficial to run at say 230mhz @ 8-4-4-3 vs. 220mhz @ 7-3-3-2.5?
