How many SATA controller can go in a system?
Happy Hopping
Say your motherboard has 4 connectors to 4 SATA SSD. But you have spot for at least 1 more SSD. Can you install a 3rd party SATA controller?
And if so, would that third party controller conflicts w/ your motherboard?
Assuming it can be done, what's the best SATA controller that is high quality?
Further, if there is only slots for 5 SSD, knowing they are only 2.5", is it doable to use cable ties to strap a few more SSD inside the computer somewhere?
What would be the purpose of controller cards if you couldn't use them like that? High quality is all relative. I can name some high quality $800 controller cards and $100 ones. All depends on what kind of features you want out of said controller. As for the drives, can you think of a creative place to put them inside your case?
If your motherboard has a spare PCI-E x1 or x16 slot, yes. If you don't mind pretty much castrating the performance of the SSD and have a spare PCI slot, then yes to that as well.
Generally no.
As Blue Fox noted, you're gonna have to be whole lot more specific as to what exactly you want in that controller. Saying just "high quality" in regards to storage controllers is akin to saying to a waiter at a restaurant "I want food". See how that's not very helpful?
Depends on the case, depends on creative you are, depends on whether or not the space is suitable enough, etc.
I think a bigger problem is the lack of power connectors. I just remember it doesn't have a lot of SATA power connectors left, after it supplies 4 x SATA power connectors for the SSD.
I am thinking of Adaptec that uses a PCI E x 4 slot, but w/o power, it's pointless, unless I go to external, but I don't want to go that far
There are molex to 2 x SATA power adapters out there.
Which Adaptec are you talking about?
If you have any 5.25" bays unused, there are some 5.25" cages that hold 4 2.5" drives.
http://www.newegg.com/Product/Produ...105&cm_re=adaptec_sata-_-16-103-105-_-Product
http://www.newegg.com/Product/Produ...058&cm_re=adaptec_sata-_-16-103-058-_-Product
I trust this brand name, it's a Real brand name. The 2 card is about the same, I think the only difference is the low profile vs. regular.
I don't know a lot about those molex to SATA converter, from this link:
http://en.wikipedia.org/wiki/SATA#SATA_Revision_2.0_.28SATA_3_Gb.2Fs.29
it says there are some w/ the 3.3V missing, so I guess I have to find a good one. But even w/ a good one, it's a parallel split, so needless to say, the current would be divided in half.
Now, as we all know, the data in the SSD is important, is there enough split current to power the SSD? Is it too risky?
You're worrying about nothing. This is what I meant by molex to SATA power adapters:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816015
Turns one molex into two SATA power connectors. It's not risky at all. SSDs do not use that much power. one molex will probably be more than enough for 4 SSDs..
In that case, I only need to find out if Adaptec needs Gen 1 PCI E x4, or Gen 2 PCI E x4, because that machine only have 1 PCIe x 4 Gen 2. Although it also have 2 PCIe x 8 Gen 2.
Does any1 knows if you can plug PCIe x 4 into PCIe x 8 slot?
how about instead of hypothetical questions without much information, you give us a list of what hardware you have and we will tell you what will work with it? is there some reason you cant just say "i have a xxx motherboard with xxx number of SSDs and a xxx power supply."?
Yes you can. And what do you mean by "Gen"? Did you mean PCI-E 1.1 and PCI-E 2.1?
that's right. They called it Generation 1 and 2.
Now, for future planning, if there is a good brand name, I would go with a controller card that support 8 SATA drive
http://h10010.www1.hp.com/wwpc/us/e...9-307907-4270224-3718645-3718646-4193573.html
this is the computer coming next week. I won't be buying SSD from Intel G2 series until their G3 come out, hopefully by then, they'll be a lot cheaper
