How many amps will I need to run my computer,lcd monitor,printer,cable modem,router and speakers? Do you think a single 20 amp surge protector and wall outlet is enough? Or should I split the equipment up and use two seperate outlets?
Do yourself a favor and get a Kill-A-Watt. Comes in very handy for lots of things and would tell you how much you can put on one circuit.
Put the printer on a separate circuit that is fed by another phase/leg. They cause a voltage drop when they first kick in, lot of UPSes don't react well to that and won ttrip fast enough and the PC may reboot. You can sometimes unplug the UPS before you print something but kinda annoying. Obviously, the printer should NOT be on a UPS.
How does a Kill-aWatt tell you how much you can put on one circuit? The circuit breaker's rating does that, normally.
The circuit breaker's rating is only useful when you know how much power your stuff draws. But a K-A-W is a crappy meter that doesn't work well with reactive (non-resitive) loads. I'd sooner recommend a Baytech managed PDU on Ebay that contains a meter. I got one for about $40, and it's way more useful than a stupid Kill-a-watt (though it's somewhat larger).
The kill-a-watt has PF correction.The circuit breaker's rating is only useful when you know how much power your stuff draws. But a K-A-W is a crappy meter that doesn't work well with reactive (non-resitive) loads.
