diff between full and quick format is that the full format checks for bad blocks so yes 8tb will take forever. You should have tested each hard drive individually before putting it in service that way you know the drives are good and can just do quick format.
This has been a question on my mind for ages, do the bad sectors found by a full format LAST? Meaning does the system even remember that there were bad sectors once you do a quick format? I'm thinking that bad sector scan done by a full format only applies to that format.diff between full and quick format is that the full format checks for bad blocks so yes 8tb will take forever. You should have tested each hard drive individually before putting it in service that way you know the drives are good and can just do quick format.
I believe they did last at one point.This has been a question on my mind for ages, do the bad sectors found by a full format LAST?
