Ok, so how long do you usually try to be "prime stable" for before just going into everyday use?
With my new 8400 and Gigabyte DS3L I've got it set at 4.0 ghz and BIOS Vcore of 1.38785.. the one right below 1.4. (CPU-Z shows 1.36) I get to about 17 hours of Prime before core 1 craps out.
Temps are fine, never goes above 55c on a Noctua in Push/pull. Memory is fine after an overnight run of memtest. I've bumped up Northbridge and FSB voltage by 0.2 in bios.
Should I push for 24hr stability or just go ahead and use it? (Normally just gaming, nothing intensive like video encoding)
