how long do most cards live for?
8800GTS
thats only 15mins tho, i usualy play for a few hours.
I wouldn't worry about it. As long as at least 75 of the tape is still touching the memory chip, then the heat should get dissipated
i asked this earlier but never got an awnser, how much dust is bad?
i have dust build up at the ends of the fan blades that i cant reach, like the dus that builds up in your keys on ur keyboard. is this bad?
Well, it's hard to say without seeing it in person, but if you have "long strands of cat fur" on the heatsink already (considering how new this card has to be) then that doesn't sound good. However, I have seen PCs practically caked in thick dust still running stable.
Considering your cat fur problem you should probably clean it out with a canned air and vaccum once a month or so.
And no more Q tips, there's no need to clean out the space between the heatsink and the card, in my opinion, beyond shooting canned air in there. Just try to clean out the heatsink fins of metal with canned air and you'll be fine.
Here is an example for ya:
I have an old 5900 NU I bought 4 or so years ago that has been in a machine running 24/7 for the entire time. Hardware is designed to last forever. Only flaws or abuse will break it.
All my previous cards lasted longer than I used them.. From my EGA cards way back in the 80's to a 9600XT and everything in between.. Avg use was about 3 years of active heavy use per vid card. Lots of school work, BBS's, and vid games back then.
However my 6800GT only lasted 2 years before it died. I'm not surprised, since under heavy gaming, it would see about 80ishC. It never overheated (since Nvidia set the upper limit to 120C, but I suspect the heat shorted its lifespan) BFG stood by their lifetime warranty, no hassles for a RMA.. Still using a 6800GT now. Since Nvidia and BFG set the upper limit of temp 120C, I am hesitant to say, 80C during extended heavy loads is acceptable on this card. I actually worry about my HD's the most being subjected to that heat.
The new 8800's with their dual slot design seem to be better, since it seems like they "only" spike up to 60C under load from all the reviews? I wonder if it will have internal dust buildup over time. The 6800GT reference cooling would hide and collect dust under the top plate, even if you cleaned the case regularly. So I wonder if the 8800's will suffer that same fate over time.
I'm sticking with BFG (or EVGA perhaps, hear good things) for the lifetime warranty on my next card (probably a 8800 variant). Video cards are so complex, power hungry, and hot now, its worth the "insurance".
I still have a RivATnT2 N64 on my antique PC. It has been 7 years, no problems. Never needed to RMA it but my 7900GT needs to be RMA'ed in only 6 months of usage due to a fallen capacitor.
im worried about my new problem, i just got done play armed assualt and i hit 72C. i only played a few minutes. this isnt normal seeing as i never use to hit this high of a temp.
edit: i think its just that game, its a pretty demanding game id say.
i just played oblivion for 18mins and hit 66C. you guys think this is normal?
will my temperatures increase ALOT if i play for 3 hours? do you think they will go over 76C?
72c is fine.
just so you get the idea, my grandfather is still using a P300 system bought 8 years ago to play minesweeper and browsing internet, this pc has often been in very tough environmental conditions, has often been moved around/transported to other places, not a single component was replaced, not a single time it failed to boot, it is amazing and always filling me with confidence of pc hardware durability.:eek:
hehe I remember reading a review about PC that has been completely abused. You can see huge speckle of dust thats completely blocking the air inlet and outlet. I have no idea air can pass through that damn thing but whaever it is the fans are sure overworked like hell. those were the days.
right now I can assure you that any modern system facing situations like that will get toasted immediately. So it will be a good idea to open the case and clean some fans before its too late. Any gc that reach core threshold temperature ONCE won't be good news anymore. As long as the fans are working great, the cards can live forever (if all components you see are well soldered into)
quick question
when you play a game do the temperatures rise more the longer you play?
say you play for a half hour, you hit 65C, play for another hour will you hit higher like 70C?
so will there be a diff in temperature if i play for 1 hour or 3 hours?
exactly what I am talking about.
Heat and Dust, if you dont battle with them constantly you'd better NOT own a pc, the situation you described is equivalent to obturating a person's a-hole and penis so plague builds up within resulting gradual destruction of organs, in this case hardwares.
So I modded my case, 4 additional fans added.
I open the case and blow everything with a mighty blower once a week, and I could often see dust and trash splashing outward.
And I constantly search for better cooling solutions.
If you feed them well, take them for plenty of walks and make sure it has all it's shots....it should live for 8 years or so.
:p
Honestly though, I still use my 9700 Pro every day on my old rig, and I even have a Trident card from like 1992 or so that still works fine! I take VERY good care of my gear though, always cleaning it and maintaining good air flow.
I'm still using a Radeon 9800 and it's past the 4 year mark.
If you avoid overclocking hard, hardware will last a while.
quick question
can som1 awnser this question?
Man, hardware runs forever. Follow me! :)
I have a Am386DX-40 board (made by PcChips) that I powered on about 1,5 years ago and it was working OK.
I sold the ISA video card I used to test it, so I am not able to see if it works correctly now.
BTW, I am from Brazil. It's not rare to see Pentiums I and II making some folks happy around here.
I am writing this on a Duron 1.6ghz system for that matter. Runs XP just plain fine with the good old ECS K7S5A... but I still want to put some DDR SDRAM. (yes, the good old SDRAM still going on strong here). I have the GeForce 6200 Video Card that satisfies my gaming experience greatly.
My sister uses a Pentium III 500MHz, Asus P2-99 with a Diamond Viper II Video Card, everything bought brand new in April/2000. Works damn fine too.
In my left, there is an AT case with a PcChips M748LMRT MotherBoard with an Pentium II 400MHz processor in it, along with 128MB SDRAM (2x 64MB). It was my old box. Works fine too.
My brother got a new PC, to replace his Athlon TBird 1.1GHz (that is now on my mother's office, on an Asus A7V, 512MB PC133 SDRAM). It was not satisfying his gaming experience anymore. He bought an AMD Athlon 64 X2 4200+, on an Abit KN9S, with an 7600GT GeForce.
The first thing that dies is usually the HD. RAM sticks die if you're not careful with the static thing when you handle them.
Other than that, just keep things clean, fans running smoothly (clean the dust, put some oil on coolers that does not use the "Ball Bearing" system) and you'll be fine.
The oldest card I had was an ATI All-In-Wonder 7500 VE that lasted 4 years before complete and catastrophic failure. After death I abused heck out of it trying to guage how delicate these things are built. It was one stout and scrappy SOB. To think I used to worry about the random "nudge" here or there - hah.
quick question
please can someone awnser the quote and this
and is the little build ups of thin dust that sit on the ends of the flan blades, that i cant reach, bad for the fan?
I would say temps remain constant with maybe a few degrees change. My temps always stay at around 70-74c. Doesnt matter if its 5 minutes or 3 hrs. Just get some canned air and blow it around and you should be fine. A little dust wont kill your fan, alot will.
i was playing oblivion for a hour and on ati tool it sayd max was 72C and average was 65.5C.
when i check riva tuner the highest it went was 66C.
i installed new drivers for my 8800GTS because an error that poped up told me to. So i had to put new settings on; change everything to high and resolution 1680 x 1050.
any ideas?
Edit: hit 69C playing source.
I think you are worrying too much.
Are your games running smoothing? No artifacts, blue screens, etc? If so, just stop worrying about it, it's a piece of hardware with a lifetime warranty. Play with it and if it dies you RMA it, simple as that.
If you don't own canned air, buy some. Any dust you can see with your eyes you should be able to clean easilly with canned air.
And no, I didn't mean that you should stick the metal extension of your vacuum in your case and go nuts. Whenever you use a vacuum it should be one designed for electronic equipment.
Bottom line: Buy some canned air, squirt squirt squirt, and just relax.
