It probably takes a couple of hundred years for the environment to decompose the plastics used in the card.whats the average life span of a vid card used for heavy gaming.
i have a 8800GTS playing games on max setting on 1680x1050
ok i got a question a bit off the topic, i was cleaning my gpu with a qtip and people with a g80 should know what im talkin about. underneath the hs there are these white foam things, i chipped one. i usually idel at 55C, when i turned my comp on it was fine ideling at 55C but now im ideling at 58C. u think this is caused by the chipped white foam thing? or do u think it just rose for som odd reason?
edit : i think this just randomly happened, i just did a artifact scan for 10mins only hit 76C, and now my temps r ideling at 55c again. just thought ide get ur opion on this.
can som1 awnser my above questions tho?
also i had a 6600gt in my sisters dell and when it died i pulled it out and the hs was filled with thick dust, do you guys think thats why it died?
100,000 hours is 11 years. I hope you dont expect to use that thing that long.
The white foam thing is thermal tape. It's what's used to transfer heat away from the memory chips and onto the heatsink. Without the tape, that memory chip will not be cooled by the heatsink. I may be wrong but I dont think so.
i chipped the edge of the one closest to the fan.(the smallest one)
edit: ok now im scared, i think i did mess something up i played only 15 mins of oblivion and i hit 69C.
I would like for stock speed (Non overclock), silent pipe (no fan), easy 10+ year. I still have some old card running older Pentium back in 1995.
Im a bit confused as to why you felt the need to take the heatsink off and clean the GPU? I don't want to sound insulting but if you didn't even know what the "white foam things" were for, what were you doing taking the heatsink off? Furthermore, how is it possible that your card got dirty enough already that you would even need to take the heatsink off? I've run cards for a long time in a cigarette smoker/slob's house and they get pretty filthy, but nothing that has ever required me to take the heatsink off.
I'm just curious, that's all. You have a lifetime warranty, so just calm down, use the card for a while, and see if it causes any problems.
Dunno man, the fan on my Ti4200 just crapped out. Been using it since I got it (way back in the day)
