Mark Larson
- Apr 16, 2002
Building a computer for $500 is old hat. This time, I wanted to keep my outlay to a minimum and still have a PC that you could build today but still upgrade if you found some money walking the street tomorrow. So OEM's were right out.
The last PC I built was way back in 2005, and even that was a semi-built - it was a barebones and I ordered it with CPU, so it came installed with the HSF in place. All I had to do was plug in the drives and RAM.
This time, I took a different approach. I'm starting from scratch. I still need to decide what I'm going to use it for, but the most effort it'll exert will be in Quake4 and Sims 3, not to mention Hulu and Netflix and any 1080p files I can Dare to Download.
I had the following components laying around. Don't ask why I had the CPU, I just did. I'm posting the prices I bought them for. If I had to buy a CPU today I'd probably get an Athlon II X2 940.
AMD Athlon64 X2 3800+ Retail Box (Includes HSF) $35 - July 2007
DDR2-800 A-Data RAM (2x1GB Kit) $11 - December 2008
Hard Drive (320GB, 7200rpm) $30 - January 2009
Radeon 3850HD $35 - January 2009
The RAM was supposed to go in my current system (Acer OEM) but the motherboard isn't too happy with all 4 slots occupied. The Graphics card was only bought because I wanted DVI to go with my shiny new monitor. It actually fit in the Acer OEM, PCI-E connector and all.
I don't game so I don't need fancy graphics. With this motherboard, I (think I) can have two monitors plugged into the DVI/VGA/HDMI and two in the dual-DVI on the graphics card. At the same time.
I did some research, and bought the following parts.
CoolerMaster Elite 335 Case $35
Thermaltake 430W PSU $19
Asus M3A780G-EM Motherboard $57
Many thanks to Bing cashback.
So I have a total of $222 invested in the system. All shipping and tax included.
If you use current prices, you can get a better CPU etc. I'm probably going to upgrade the CPU if I find the 3800+ doesn't fit my needs. With this motherboard and RAM I can get up to an AM3 Phenom II X4. If you want more RAM, you can buy a 2x2GB kit and have 6GB of memory. For Windows 7 and my usage, 2-3GB is fine.
