edward78
- Aug 21, 2011
To take thus case, move the PSU to the back & put it to the side by the mb??? http://www.silverstonetek.com/product.php?pid=503
I mean...
Are you talking about this as a custom case design, or as a mod to the existing case?
If it's a mod, it could be done pretty easily, but why in the world would you want to do it? You'd be giving up having expansion slots for basically no reason.
Do you mean above the gpu as in stacked "on top" so that you have one case panel, the gpu, the psu, and then the other case panel?
Perhaps this discussion would be easier with a couple quick sketches.![]()
"edward78, post: 1042977910, member: 236754"]Yes, it would work right?
You will find plenty of discussion of Flex ATX / 1U PSUs here, several cases like the Hahutzy XS, the Firewolfy MI-6, that crazy mATX SLI use one.
