www.bbc.co.uk/science/humanbody/sleep/sheep/reaction_version5.swf
single fastest i've been able to get is 0.114 seconds.
Do I have to post it or can you just believe me?
0.15
Now you all should believe me when I say I can tell the difference when I use a Killer NIC,
You could be using dial up, and it wouldn't make a difference. Once the game is downloaded to memory, your ping and network speed don't matter. You can unplug your ethernet cable and it wouldn't affect the game once it's in memory.
So your Killer NIC advantage is all in your head.
A Killer or hardware NIC cant help your ping and network speed, only your provider and other things 'upstream' can help that. Calling up and havng things like interleaving removed/reduced is one way. Otherwise, I dont want to take this thread off its topic, but you should really look into what a Killer NIC really does before you say its 'all in someone's head'. What it does is at least as significant as the interface lag that LCD's have (not their pixel response). A simple way to put it is this: way back when, hardware modems were the dial-up method of choice because they off-loaded the processing/sorting of data as it came in... now, broadband has increased the speed and width of our internet, but we instead defer to using the integrated LAN controllers which depend on the CPU to actually process/sort info. On some cheaper integrated LAN controllers, like the Atheros L1e that Asus put on my last mobo, the CPU use was so high that I noticed the 'chop' because although alone it shouldnt have been much, the CPU was also taking care of crossfire/SLi operations, as well as the onboard audio. When I tested the LAN, it was putting a good 30% load on one of the phenom's CPU's! Dont hardware NIC's for our PC's make sense?
except BladeVenom is completely correct.. the killer NIC has no effect on a flash game.. since the games pre-loaded into your memory/temp data.. so its all in the guys head..
Oh, okay, I see whats wrong here... I NEVER SAID THAT THE KILLER NIC was having ANY effect on THIS game right here... thats something that is in your two heads!
I was only stating that with such an amped up reflex time, I am more likely to notice these things (Killer NIC, LCD lag, etc) than most...>>> "with other games". I know the NIC doesnt matter here. I just meant in general.
or you should just relize its a game.. and no one really cares.. but eh.. what ever..
Dude watch out!
He can tell when his FPS drops below 60Hz which makes him srs bizness.
