How does my new Intel build look?
gr!m
It's been a while since I've built a great desktop PC, my last build was stolen about a year ago and I had an Alienware m17x R3 laptop with an i7 and GTX 560m running 1600x900. Just curious of the performance differences you think I will see. I do plan on overclocking and the machine will primarily be used for gaming, converting video and web design. Ive already purchased everything but I can make changes/additions.
Gaming and web design with some video conversion.
$1200 inlcuding shipping
Charlotte, NC
CPU, RAM, Motherboard, Case, PSU, Windows 8, DVD Drive, Cooling solution, GPU.
N/A
6) Will you be overclocking?
CPU - Yes, GPU - Light OC
1080p - Not in budget, already have this.
This week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing in particular. I want to go modern with SATA III 6GB and USB 3. Also good OC features.
Nope. Got Windows 8 64 bit.
Intel i5 3570k
Cooler Master Hyper 212 Cooler - Probably going to get the Corsair H100 after the holidays.
MSI Z77A-GD65 Motherboard
8GB Corsair Vengeance DDR3 1600
Sapphire HD 7970 Dual-X
Kingston Hyper-X 3k SATAIII 120GB SSD
Seasonic G-Series 550w PSU
Corsair Carbide 300R
I plan on mostly OCing the CPU and lightly OCing the video card. What do you think?
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you.
Though the CPU is fine for now. Though you're missing the HSF needed for overclocking.
Which Corsair Vengence RAM did you choose?
The rest of the build looks ok. I have some reservations about the SSD but I'm gonna let it be.
This stuff. Made sure to get the 1.5v. Also have a 1TB WD black going in as main storage.
Dang. Well, like I said I already ordered it. I'll be getting the H100 water cooler soon enough so I wont worry about that.
