How do you test your systems watt consumtion?
I dont think you can, unless you want to break out a multimeter.
Put an ammeter in series with the power supply on the AC side, then use P=IV. That's how much wattage the PSU draws. Multiply by the PSU efficiency to get how much of the power your system uses.
I have a unit called a Kill-a-watt which can measure wattage used. This is the only accurate method since most of the online calculators assume too high of usage. My XP 2800+, 2x 512mb, Radeon 9800, 2x 7200 RPM and 3x optical drive system only pulles about 250 ish watts AC, factor in 70% efficiency in the power supply and I get around 175 watts DC used in the system, the online calcs I tried said it would be over 350+ watts used, far from accurate.
You would have to do this for every connection.. on top of that you have to have good hand to be able to make sure that ground is connected. you can't just connect the power wires in series.. you have to make sure everything else is connected.. or else you can damage stuff hardcore.. i personally would never do that.. too risky..
Also, as someone said before.. power usage changes, as different components are being used... i would say. if all your stuff works good.. then don't worry about it..
My APC UPS has software that tells me the current draw - with the monitor connected too it was somewhere just under 300w for the system in my sig at idle.
How many AC connections does YOUR power supply have?
I second the Kill A Watt, froogle it. It's about 30 bucks.
I ordered one the other day, should be here today. I think I'll write a review.. :)
-scoob8000
LOL
depends on which PSU we are talking about, all my N+1 and redundants have 2 outlets :p
luckily so does my ammeter :p (you can barely see them on the right side)
My APC UPS (ES 350VA) does the same, except it's hopelessly inaccurate. Somehow my HTPC (with a 2000+ Palomino running Folding, two hard drives, etc) draws 50 watts...
You can do it with a multimeter that can do AC current measurement, but you still have to account for your power supply's power factor. Best thing is to get one of those Kill A Watt things.
I thought this dude wanted to check how much power each individual device used.. such as HDD... i was thinking about connecting molex in series with the drives... wwwooooppps
Well, I got my kill a watt.. Very cool device..
My main rig XP 2600+, GF4 ti4200, 1 250GB drive, 1 CDRW, 1 DVD-ROM consumes 260ish watts at full load, and about 240 at idle.
This doesn't include my monitor.
At the other end of the scale is my smoothwall. AMD k6-2 300, one HDD, nothing else. Pulling around 80 watts.
And for giggles, my Baystack 350t switch draws right around 60 watts..
No wonder my electric bill is so insane..
-scoob8000
1) Record electricity Meter at 12 am (after everyone goes to bed).
2) Record electricity Meter at 6 am. (before everyone gets up).
3) Repeat 1 and 2 the next night with the PC on and at idle or full load depending on what you want to test.
4) Profit.
It won't be exact, but pretty close. Repeat on multiple nights for better averaging.
@scoob8000
You saved me $30 :) haha my setup comes very close to yours, have you tested your monitor power drain yet?
4) Profit.
that sounds like an experiment ill try myself. never thought of doing that.
[Edit: i would have to subtract the consumtion from the fridge and the clock displays on the stove, microwave and vcr]
You would not. Those devices would be in the consumption for both nights. The only difference would be the PC.
awdark said:
@scoob8000
I have a 19" NEC Diamondtron.. Uses about 120-150ish on, and about 15 in power save..
I love this kill a watt thing, I'm running around testing everything that has a plug.. :)
-scoob8000
And the fact that it's later in the year and you're probably going to have a heater on, it's not going to be the same temperature, and things like heaters will use different amounts of power every night. Or if you're in the south, perhaps you still use an AC.... Or something of that nature. Point is, this is a very bad way to test it.
