I haven't tried any VMs yet, but I already installed VMware on one of my machines and will attempt a quick Linux install with one SMP client and see how that goes. From what I've seen so far, I would much rather Stanford bring the Windows clients up to performance par than go all-out with the VM route. The additional configuration of all those VMs can be overwhelming, especially with a large farm and the lack of alternative OS familiarity, not to mention monitoring hassles and additional memory overhead. It can be really daunting if one has many machines. It's the main reason I avoided that route so far.
The only reason I'm even entertaining the idea is due to the fact my production is nowhere near where it should be with all the cores I have running. The brute force approach has its limitations.
[H]ard|DCer of the Month - February 2007/January 2
Pure SMP VM's here.
Once you have a disk image that works, then cloneing it is a five minute job.
Its making the disk image that does what you want it to, is the hard part.
Plus I'm running 99% p2605, which is probably the best protien to crunch.
If I dont get p2605, then I get p2563 which is the second best one to crunch.
Hence ~45k PpD from only 140 Ghz.
I have not yet spent the time to learn anything about linux other than the fact that it is free. I would like to eventually. Some of the people in my social life (read girlfriend) say I spend too much time with my computer as it is.
As a side note, for the first time the one in italics is winning.
Same here. Most of my quads are running a Windows host and two VM's of Ubuntu 8.04 64 bit. I have one 3Ghz quad running PCLinuxOS as a host with two Ubuntu 8.04 64 bit VM's and its getting right about 12:05 a frame. I'll likely be converting most of my other quads to the same host/VM conbination in the future to get the same drop in frame times (hopefully).
I will expound on my previous reply now that this damn work computer isn't freezing up my system for 10-30 seconds at a time with only about 5 seconds to type something.
The reason my VMs are getting much better PPD is because they are pulling on 2605s almost exclusively. Because VMWare Server has a limit of 2 CPUs per VM, the F@H client identifies the quad as a dual core only machine. This way you don't get any or at least very few chewy work units since most of them are aimed at quad core machines. That's why my Linux install running two native Linux SMP clients don't get nearly the same PPD as my other two quads.
When I had my X2@3.0Ghz running the SMP client it was always pulling the 2605s as well. My main system actually pulled 2 2605s the other day and I was doing over 14k PPD between the three machines. If I was running F@H on my X2, I would have been doing almost 15.5k PPD between the 4 machines.
Windows native here, 2 x SMP and AC. It's good for 4200ppd on 2653's, but drops to about 3400-3600 if I'm crunching 3062's. Those are the 2 I usually get.
WinSMP exclusively at work with AC (dual-cores only)
laptop running native linux smp (dual-core)
1 Q6600 box running native linux smp for betatesting (ppd swing between 1900 and 5000 depending on what WU).
3 Q6600 box running windows as host and 2x linux SMP VM
1 Q9450 running windows and 2x linux SMP VM
The linux SMP VM is the best in terms of production but hopefully, this might change with the new A2 core.
