How do you know if a MB is doa?
nubbin77
I bought a Cheapo AMD M2 Mobo (PC Chips A11G nforce 6100 chipset) for a "just surf the internet" computer.
I've built around 8 computers in my life but never experienced a DOA (I guess I am lucky). But before I start the RMA process, I'd like to know if there is a way I can check for certain. I've hooked up everything, but when I hit power, I get nothing. Not a thing.
So I reconnected the case cables. No change - the case was working before.
I tried a second PSU - no go.
Can a bad component cause it not to turn on? Like a bad CPU or bad piece of memory? Should I unplug everything, including the cpu and memory and try it (I know it wouldn't post but maybe I'll get some power and beeps?)
I guess my dilema is this: I am not 100% sure it is the mobo although I think it is the most likely. I have 2 psu's - I'd say there's less then a 5% chance both PSU's are bad.
The case, while shitty and has a really crappy on off switch (hard to know if its even switching) it did work for the last computer it housed. Is there any way to test a case to see if the connections / switches are bad? Or the mobo. I'm guess that is the most likely candidate. I just didn't want to rma it, get another one and realize I replaced the wrong component. Any advice?
There is the outside chance that I have not connected the case right even after 2 tries. I guess I'll do that again. Does nothing generally happen when you hit the power if its a bad board? Should there have been a POP or anything?
Another way to get the board to power on is just by shorting the pins for the switch with a screwdriver, or anything metal that fits between the pins. I did this when selling my old 3500+ and neo2 as few weeks ago.
Oh man I must be getting older but not wiser. After reconnecting the case for the 4th time, I connected it correctly. I put the power led in the power switch spot - after taking it out and putting it back in 3 times, each time checking the manual.
DUHHHH STUPID ME....
Well, just recently I thought a board was DOA, but it turned out I just had two bad PSU's :cool:
