tpfaff said:Ok so I just ordered a gigabyte GA-965P-DS3 amd ive heard of the posting issue, my ram is rated at about 2.0 volts also, so i think i need to flash the bios to f4 as opposed to f1? How would I go about doing this.
GonzoP said:BIOS flashing as evoled many can be flashed in windows itself it will depend on the make and model. Definitely have to go directly to the Gigabyte website and DL the proper BIOS
tpfaff said:ok thanks! I havnt even looked into flashing IN windows. Thats cool you can do that.
kirbyrj said:Flashing your bios is usually explained where you download the bios file from. Most manufacturers have their own Windows based flash utility now. I finally ditched the floppy, so I just use Windows to flash.
