Try out Audacity, it may do what you want
Sounds like you already decided, but I'd vote for super as well....that program is awesome. It'll convert anything I throw at it, to formats I never even heard of. I'd highly recommend checking it out.
That's better.If you're comfortable with the command line, just download ffmpeg.
Your tagging issue is probably because the files have ID3v1 tags to begin with, and foobar doesn't (I think, I use a different program for initial tagging) *add* new tag formats to a file, though it will modify any existing ones.
SUPER
if you can figure out WHERE THE F#CK TO CLICK TO START THE FUGGIN DOWNLOAD@!!!!!!
