jokerx225 said:There is no overheating. I updated the Bios. the rig does freeze somtimes but i think i have the wrong timings on my ram which imma fix in a min. I have Anti Spyware. What drivers are you talking about? when i go into System Properties it says i have Amd X2 4400+ but when i go into task manager it doesent show 2 cores
manually set timings and set ram voltage to 2.7vjokerx225 said:the rig does freeze somtimes but i think i have the wrong timings on my ram which imma fix in a min
freeloader1969 said:Sounds more like your suffering from an I/O problem. You can have a 10 processor system, but if 3 to 4 applications call on the I/O subsystem (hard drives, cd-roms, floppy drives...etc) at the same time, you can have lag. It's basically equivalent to running a virus scan on your hard drive, installing a game and listening to music off the hd all at the same time. You can have 2 processors or 10, you'll have I/O lag. It basically shows itself as a stutter.
well, that's why I'm pumped about the consumer solid state solution that's on the horizon
where'd you see that?ElaborateDream said:mikelz85: The Gigabyte part will only address the RAM with a 100MHz clock. So, I believe any RAM from PC1600 upwards should be golden, I know I'll stock mine with spare PC2100.
