Hello.
I was recently advised to get a radeon HD 6450 card to replace my failing Nvidia GT220. I purchased the card and now I cannot play diablo 3 or lineage 2. Diablo 3 tells me the card is not supported and I'm ok with that. But, the game I'd like to play is lineage 2.
When I launch that game I get the following error:
2013.12.7 20:24:03 [GTick=1 LGTicks=1]
Build Date : Fri Nov 01 01:03:47 2013
OS : Windows7(32) 6.1 (Build: 7601), Service Pack 1.0
CPU : AuthenticAMD AMD Athlon(tm) II X2 250u Processor @ 1607 MHz
RAM : 4095MB RAM
LOGICALCORE : 2
PHYSICALCORE : 2
Video : AMD Radeon HD 6450 (1230) Direct X version is 4.9.0.904
PosCode : LS1(558) 0:0:0 2/0 [731]
Video Resources : 0 MB
Please enable Direct3D acceleration. You can do this by starting dxdiag and enabling Direct3D Acceleration in the Display 1/2 tab after installing DirectX 9.0C (or later) and the latest drivers for your graphics card.
History: General protection fault!
History:
The error log instructs me to enable direct3d acceleration. When I run dxdiag the option for 3d acceleration is not available. I've tried to find direct x 11 to download, and everything I try tells me I have the most up to date drivers. The Catalyst control center does not seem to offer any fixes. I've found a fix to check my computer>display>advanced and to slide the performance all the way to the right. I do not have that option either. Everything I've tried has not worked.
Can anyone help me with this issue?
Thanks.
RAM : 4095MB RAM
LOGICALCORE : 2
PHYSICALCORE : 2
History:
Thanks.
