w00tguy123
- Mar 30, 2011
I was in the middle of playing a game when suddenly the computer shuts down and refuses to turn back on. I figured it was a problem with the PSU so I changed it with one I know works and I at least get the power LED to flash, but nothing beyond that. Eventually I took the mobo out of the case and removed everything but the CPU and the speaker/indicator wires. Still nothing but a short LED flash.
I'm pretty sure the mobo is broken, but I want to know what caused this to happen.
Some important things to note:
-I was overclocking the CPU multiplier to 47 from 33 and using "auto" settings.
-The CPU was not overheating as I had a warning beep set up for that.
-The entire case was hot when it shut down. Ventilation wasn't as good as I thought.
-The PSU was especially hot, comparable to the CPU heatsink.
-No burn marks anywhere. No weird smells.
-This is my first build
Is there anything worth trying or should I get rid of the motherboard? I'm hesitant to get a replacement of the same mobo because I don't want this to happen again. What did I do wrong? Shouldn't the mobo shutdown if it's getting too hot? Was overclocking with auto settings a stupid thing to do?
My setup:
CPU: i5 2500k
MB: Gigabyte GA-Z77-D3H
RAM: Samsung Green DDR3L 1600 mhz 4GB x2
GPU: Nvidia GTX 460
PSU: 550 Watt
Storage: Samgung 840 and Crucial M4 SSDs
DVD RW drive
My setup:
CPU: i5 2500k
GPU: Nvidia GTX 460
PSU: 550 Watt
DVD RW drive
