how come my system isn't recognizing USB 2.0?
geckoman
I've got several USB 2.0 ports that are not showing anything indicating they are high speed USB.. any thoughts?
Could be hardware failure or software problems.
My onboard Ethernet is dead as well as my firewire. I think mine's a hardware failure. I just bought a PCI NIC card and I'm back in business. USB and NIC PCI cards are so cheap - if it takes you longer than a day to figure it out, you're spending too long on it.
What are you looking for them to say? Do you notice slow transfer speeds or something?
when I plug something into them, I get the message that I have plugged a high speed device into a non high speed usb port or something like that
I had the same problem when I setup my Asus P5GD1 this weekend. Look in the bios for a USB setting.. Mine had a USB 2.0 speed setting(Disabled, Hispeed, fullspeed) It was set to disabled, and therefore I had no USB 2.0 support. Hi-Speed is what you want. Also check in device manager Under USB controller for a line showing an ENHANCED USB Host Controller, If the system has High Speed USB (USB 2.0) capability. If you don't see it, then its most likely disabled in the bios somewhere.
