How can I Overclock my GPU?(Chipset)
MienTommy
How can I overclock my GPU (It's a Chipset) and this is a Store Bought Comp from Walmart.
Field Value
CPU Properties
CPU Type Intel Celeron D 352
CPU Alias Cedar Mill-512
CPU Stepping C1
Engineering Sample No
CPUID CPU Name Intel(R) Celeron(R) D CPU 3.20GHz
CPUID Revision 00000F64h
CPU Speed
CPU Clock 3199.1 MHz (original: 3200 MHz)
CPU Multiplier 24x
CPU FSB 133.3 MHz (original: 133 MHz)
Memory Bus 266.5 MHz
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID 63-0100-000001-00101111-081706-RS400$RC410-M_BIOS DATE: 08/17/2006 VER: 08.00.12
Motherboard Name HP Alhena
Chipset Properties
Motherboard Chipset ATI Radeon Xpress 200
Memory Timings 4-4-4-12 (CL-RCD-RP-RAS)
DIMM1: Corsair Value Select VS1GB667D2 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM2: Corsair Value Select VS1GB667D2 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Properties
System BIOS Date 08/17/06
Video BIOS Date 05/09/08
DMI BIOS Version 3.18
Graphics Processor Properties
Video Adapter ATI Radeon Xpress 200/1100 (RC410/RC415) Chipset
GPU Code Name RC410 (PCI 1002 / 5A61, Rev 00)
GPU Clock 301 MHz (original: 300 MHz)
and
Field Value
Computer
Computer Type ACPI Uniprocessor PC
Operating System Microsoft Windows XP Media Center Edition
OS Service Pack Service Pack 2
Internet Explorer 7.0.5730.13 (IE 7.0)
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name MIEN
User Name Compaq_Administrator
Logon Domain MIEN
Date / Time 2008-04-26 / 18:50
Motherboard
CPU Type Intel Celeron D 352, 3200 MHz (24 x 133)
System Memory 1792 MB (DDR2-667 DDR2 SDRAM)
BIOS Type AMI (08/17/06)
Display
Video Adapter ATI RADEON XPRESS 200 Series (512 MB)
3D Accelerator ATI Radeon Xpress 200/1100 (RC410/RC415)
Monitor HP VS15 [15" LCD] (CNC630PF4L)
Multimedia
Audio Adapter Realtek ALC888/S/T @ ATI SB450 - High Definition Audio Controller
Storage
IDE Controller ATI IDE Controller
IDE Controller Standard Dual Channel PCI IDE Controller
Storage Controller VAXSCSI Controller
Disk Drive HDS728080PLAT20 (80 GB, 7200 RPM, Ultra-ATA/133)
Optical Drive AG4080A ZSD409H SCSI CdRom Device
Optical Drive LITE-ON COMBO SOHC-4836K (DVD:16x, CD:48x/32x/48x DVD-ROM/CD-RW)
SMART Hard Disks Status OK
Partitions
C: (NTFS) 68033 MB (23544 MB free)
D: (FAT32) 8267 MB (361 MB free)
Total Size 74.5 GB (23.3 GB free)
Input
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse HID-compliant mouse
Network
Primary IP Address 192.168.1.110
Primary MAC Address 00-18-39-1C-E6-81
Network Adapter Linksys Wireless-G PCI Adapter (192.168.1.110)
Modem Data Fax SoftModem with SmartCP
Peripherals
Printer Auto HP DeskJet 722C on TIMMY-IS-SEXY
Printer Fax
Printer Microsoft XPS Document Writer
Printer Quicken PDF Printer
USB1 Controller ATI SB450 - USB Controller
USB2 Controller ATI SB450 - USB 2.0 Controller
USB Device USB Human Interface Device
DMI
DMI BIOS Vendor American Megatrends Inc.
DMI System Manufacturer Compaq Presario 061
DMI System Product RF800AA-ABA SR2011WM NA680
DMI System Version 0n41411RE101AlHEN00
DMI System Serial Number CNH63735RC
DMI System UUID DCEA00BF-ED44DB11-AE547D49-4CF2A66A
DMI Motherboard Manufacturer Hewleet-Packard
DMI Motherboard Product Alhena
DMI Motherboard Version 1.0
DMI Motherboard Serial Number
DMI Chassis Manufacturer
DMI Chassis Version
DMI Chassis Serial Number DM0001
DMI Chassis Asset Tag
DMI Chassis Type Desktop Case
Problems & Suggestions
Problem Disk free space is only 4% on drive D:.
It's not worthwhile, if it's possible at all. Even running at a 200% OC (not possible) it would still be slow. You need a proper, dedicated GPU. The IGP will not cut it in any modern titles.
I don't even think that is possible. If it is, like silent-circuit said, you will not see any noticeable gains at all.
Since it is an Ati Express 200, either the Catalyst driver suite's own Ati Overdrive or Ati Tool may be of help.
Not that over clocking it, (if that is possible), will benefit you much.
Ehh, maybe it will let you bump a setting or 2 in source games.
where can I get overdrive?
I think your best bet is running your entire computer at 220 V :D
or if you want to Really overclock that sucker to high-speeds, 440 V :cool:
j/k
