baballin328
- Sep 7, 2006
Tigerdirect has an FX-60 barebone for $400. It's pretty hot considering FX-60 is going for $460 on newegg. Great for a budget system, not sure about the mobo though.. http://www.tigerdirect.com/applicat...tId=1916&CMP=EMC-TIGEREMAIL&SRCCODE=WEM1281AM
Ultra X-Blaster Black ATX Mid-Tower Case
When looking for subtle styling, durable quality and unparalleled ease of use, look no further than the Ultra X-Blaster. The X-Blaster supports AT, baby AT, ATX and micro ATX motherboards and features 1mm thick high grade steel. The X-Blaster has 10 drive bays. Four tool-free 5.25" drive bays, one external 3.5" bay and five internal 3.5" bays.
- Form Factor: ATX Mid-Tower
- Expansion Slots: 7
- Material: Steel
Asus A8S-X SiS Socket 939 ATX Motherboard
The ASUS A8S-X offers the best value for a AMD based motherboard. In addition to support the latest Athlon X2 process, A8S-X provides PCI Express architecture designed for the lastest VGA cards and is equiped with robust Intel Gigabit LAN suitable for reliable and performance networking environment.
- Chipset: SIS 756/965L
- Front Side Bus: 1000MHz
- Processor Interface: Socket 939
AMD Athlon 64 FX-60 2.60GHz OEM Processor
AMD64 technology shatters barriers to new and advanced software that require 64-bit technology and blazing processor performance. Power-hungry enthusiasts, gamers, and prosumers can explore the full potential of AMD64 technology while enjoying outstanding performance on todays PC software.
- Processor Speed: 64 FX-60 / 2.60GHz
- Bus Speed: 1000MHz (2000 MT/s)
- Processor Socket: Socket 939
Ultra V-Series 500-Watt ATX Power Supply
This new Ultra V series power supply offers more connectivity choices than the typical power supply, with options for 20/24 pin motherboards, SATA and PCI Express connections.
- Supports AMD and Intel Motherboards
- Thermal Overload Cutoff Protection
- Low Acoustic Noise
- Material: Steel
