*HOT* Socket Bluetooth GPS Receiver $105.95 shipped!
karrock
Package includes Bluetooth receiver and car charger. No mapping software, but anyone that's shopped around for Bluetooth GPS knows that these units are easily double the price sans software.
http://www.expansys-usa.com/product.asp?code=119717
Well the store rating should be going up. I picked up the gps and it arrived today exactly as claimed (packaged by Socketcom). It came with the 'Y' car connector.
Update: Expansys pulled a fast one that I had missed. When I ordered the GPS it showed that it was the 16 satellite model but they have since updated the page (and shipped) the 12 satellite model which is not nearly as good.
Hm, perhaps their reseller rating is justified?
Yep, I got mine two days ago -- the OEM all-black one looks much better than that bright blue one... stealthier! :D
On an interesting note, the 5V 2A charging (positive center) requirement and connector matches up perfectly with the PSP's AC adapter, and I'm sure some of those USB charging cables out there would work as well. On the flipside, that means that the car charger I got with the GPS will charge my PSP! Wouldn't it be great if all manufacturers had interoperable accessories?
Works great with my Tungsten T3, even though it's not "officially" supported -- paired up like a champ! Now I just need a real GPS-enabled navigation software. Been playing around with Earthcomber and a few GPSPilot apps. Mapopolis looks OK, but not to professional looking. Likely my final choice will be TomTom Navigator (unless someone knows a better package out there), but I'm debating on whether to buy 2004 when V5 is on the verge of being released.
