Oh gods... I can see it now...
"The lady in the commercial said the APU is faster than the CPU + GPU. I don't want a new HD 7970, I want the APU because it's better."![]()
This. I felt the only time she understood what she was saying was when she said "but what does that mean?"I have a feeling that airhead blond had no idea wtf she was talking about.
Totally! Can anyone explain to me whats the difference between the APU and Intel's processors with incorperated gpu?
Since when was BestBuy so educated... oh wait they have a teleprompter.
She's pretty good looking. But I don't see how that somehow makes the product better.
Sure, I'll take a bang at it. With Intel's Solution you have two chips. One chip is your HD3000 or HD2900 or whatever graphics chipset. The other is your CPU.
They are located physically nearby but a bit apart from eachother. Generally, the processor accessing the GPU requires probably sending a call through the pci-express bus, waiting for a response, etc etc. Its a pretty standard solution that basically fairly well mimics what PCs with discrete graphics cards do. However, Intel's solution is really really slow.
For example, an old laptop I have with a 2600 or so HD chipset can play WoW at the lowest detail settings with all the sliders turned all the way down at 800x600 resolution at about 7-8 fps. (A slideshow, just barely fast enough to do herb/ore farming and perhaps dailies against enemies npcs fairly under-powered). I think as we can all mostly agree upon, WoW is not known for its graphical prowless. Games like L4D for example, which too is not known for its graphics prowless, will run at 3-4 fps. Entirely, not playable. Thus the general opinion you'll find among gamers is 'lawl. intel integrated graphics. flash game much?'
With AMD's solution, the CPU and GPU have been combined into one-tiny chip rather than two chips. So potentially, for the CPU to access the GPU, a much smaller distance needs to be travelled. Smaller distance = faster turn around times = better performance? We'll see. AMD also can use its GPU technologys like perhaps 3D support, better shaders versus Intel, etc. The GPU does come with UMV HD video enhancements for example so potentially it might have 3D support for 3D movie playback on the go.
One advantage at the moment is supposibly according to AMD, when rendering games like FF14 benchmark, the game uses 25% less power usage or so ...(60 ish versus 45ish watts). So it may be more power efficent. It supports up to 8 cores were as most intel notebook processors are between 2-4 cores. Arguable whether that gives more overall processing power. We'll need to wait for some more benchmarking on this.
What has some people excited about it is videos like this:
http://www.youtube.com/watch?v=mdPi4GPEI74
If you watch this video, you'll notice/see that AMD's APU is able to render the FF14 benchmark at relatively smooth fps where as Intel's Integrated graphics choke. Why is this important? Well, we could potentially see notebooks for $399.99 that can run FF14 which is a fairly modern title on the go at 1366x768.
This has the potential to let us play newer games, equivilent to our pcs, on the go in a really small form factor. Rather than needing a heavy 19" gaming laptop that weights 10kg, has a huge power block and runs out of juice in 13 minutes if not plugged in. We might be able to see a 2.0kg netbook that has an hour of power usage and can play games at a very reasonable resolution considering the relatively small 7-10% screen size.
TL;DR version: Up to 8 cores, gpu/cpu physically being 1 chip with amd instead of 2 chips located nearby with intel, benchmarks suggesting good performance in modern games in small form factor, potential 'gaming' netbooks. PC quality gaming the size of a slightly larger nintendo ds.
That would raise her attractiveness quotient 2 points, but it doesn't quite make up for the 3 points she lost acting like a typical airhead blond.What if she is one of [H] community owning a watercooled oc'ed Sandy Bridge system along side her collection of guns?![]()
The first answer was so filled with head shaking wrongness, I'll just make a short explanation. jeremyshaw corrected one of the worst inaccuracies already.Totally! Can anyone explain to me whats the difference between the APU and Intel's processors with incorperated gpu?
An AMD APU is a programmable GPU (OpenCL, DirectCompute or AMD's own APIs) with the CPU core(s) on the same chip (die). This is the "Fusion" type of CPU AMD has spoken about for years.
Intel's Sandy Bridge CPUs have a GPU and CPU on the same die, but the GPU is not programmable in OpenCL or DirectCompute (or anything outside of OGL or DX shaders). When Intel releases Ivy Bridge in several months, it will functionally have the same parts as an APU, including the programmable GPU. Before that, the 32nm Atom may have a programmable GPU (newer PVR SGX). "May" because Intel may not support that functionality in drivers.
Minka Kelly = HOThahaha. i think anyone who thinks she isnt hot should post a pic of their gf/wife and let us rate higher or lower than the chick in the vid.![]()
