Rocky Mountain High
- Mar 2, 2006
High-end CPU air coolers, such as Thermalrights Ultra-120 and Tuniqs Tower 120, depend on heatpipes to conduct heat to the cooling fins. In the Silent PC Review test methodology (http://www.silentpcreview.com/article46-page3.html), it appears that the motherboard is horizontal and the heatpipes are vertical. While a vertical orientation is ideal for heatpipe performance, this situation exists only in desktop installations. The vast majority of heatpipe installations will be in towers where the heatpipes will be horizontal.
Anandtech, in contrast, appears to test CPU coolers in a vertical tower where the heatpipes will be orientated horizontally. Anandtechs reviews have this qualification: All cooling tests were run with the components mounted in a standard mid-tower case. The idle and stress temperature tests are run with the case closed and standing as it would in most home setups. (http://www.anandtech.com/casecoolingpsus/showdoc.aspx?i=2981&p=3)
Besides Anandtech, which reviewers test CPU coolers with heatpipes orientated horizontally?
How much does a horizontal orientation diminish heatpipe performance?
