Dec 13, 2006 #1 T Table Limp Gawd Joined Nov 18, 2006 Messages 256 how does one go about doing it? are there extra components one needs to buy? Only certain laptops have the ability? thanks
Dec 13, 2006 #2 kirbyrj Fully [H] 2FA Joined Feb 1, 2005 Messages 31,348 An LCD monitor? Most laptops have a d-sub (blue VGA) output that will connect to most LCD panels as long as it has a d-sub connection. Most of them still have d-sub and DVI connections.
Dec 13, 2006 #3 B Bacillus Limp Gawd Joined Apr 23, 2006 Messages 384 Most can/do - except for some ultra small form factors. Even then it could with the external base. Once hooked up, depending on your graphics card, you can do an extended desktop or simply clone your laptop screen.
Dec 13, 2006 #4 T Table Limp Gawd Joined Nov 18, 2006 Messages 256 so the samsung 225bw should work? yes it does
