Flogger23m
- Jun 19, 2009
I understand why mission 1-11 were so easy. They must realize they could not figure out how to get basic commands working. The more units you have it becomes impossible to command a medium sized fleet. RU collectors don't go after what is close or logical. As an example, I have three unused asteroids with 1500 RUs each. I have my RU collectors right by them. They finish mining one rock, and then the options are as follows:
1) They sit there for eternity unless you target the specific rock.
2) You click the auto harvest, and instead of going for the fresh rock that is right fucking next to it, they decide to find some obscure rock on the other side of the map that is not defended.
This makes auto harvest useless and you have to manually click each RU collector and each rock. You also cannot do this from the sensor control view, or when zoomed out. You have to manually zoom you camera right up to it as you cannot issue commands through map objects. So when RU rocks are between map objects that means you need to spend 60-90 seconds every few minutes to zoom in to issue a command. And even then not every single click seems to register.
Maybe the final mission is complete-able, but I am about to give up until they can figure out basic commands. We're talking the most basic features, like being able to issue basic orders through the sensor screen or without camera line of sight not being implemented. How fucking dumb could they be?
