Storage for the stuff listed below. Haven't decided on what is best yet for a hypervisor.
$500-600ish...
Miami, FL USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
New system - cpu, mobo, ram, drives, ps, case. Don't need a GPU as I want to use onboard video since this is just a server.
Not reusing any parts except an LCD monitor
6) Will you be overclocking?
nope
24" LCD - 1920 x 1200
The next few weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
RAID and and eSATA would be nice to have.
FreeNAS is open source.
Hello All,
I'm looking at building out a mostly virtualized full home test lab, to help train myself and to stay up to date on some newer technologies as well as test out ideas for the real world.
My first step into this venture is a centralized storage solution. This will have two functions, one to centralize all of my digital media, and two to centralize storage for my virtual servers. I have been looking into FreeNAS and I believe this will be able to handle my needs.
I came up with this budget FreeNAS build earlier today and was looking for some feedback. I also would like some feedback to see if I am just better off finding a decent used workstation on upgrading things like RAM and Hard Drives. Maybe I am better off building a beefier machine to be my hypervisor and going even cheaper on the FreeNAS build. Anyway here is what I have so far:
CPU - AMD A4-5300 Trinity 3.4GHz - http://www.newegg.com/Product/Product.aspx?Item=N82E16819113283
MOBO - MSI FM2-A75IA-E53 FM2 AMD A75 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130664
RAM - Corsair XMS 8GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145324
Disk - WD 1TB Blue SATA x4 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
PS - Corsair CX500M 500W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050
Case - BitFenix Prodigy - http://www.newegg.com/Product/Product.aspx?Item=N82E16811345016
$500-600ish...
Miami, FL USA
nope
The next few weeks
Hello All,
