Home server
Modred189
Can't Read the OP
I want to put together a home server made out of an older PC.
It's an e-machine with an Athlon 64, 3800+, 2gigs of ram, an ATI X700pro and a 200Gig hd. I want to set it for automatic backups, file sharing and storage etc.
I upgraded from a 3500+, and don't know if XP MCE is going to work very well, or agree with this change as it is an OEM version.
Anyone have any suggestions for a free/cheap OS for a server (FYI I have NO coding experience, so simple is key)?
Windows Media Center will "agree" with the CPU change. If you changed the mobo, however, and didn't reinstall Windows Media Center, then there will be problems.
So you can still use that OEM Windows Media Center.
But in case you can't, I recommend Ubuntu Linux. The community support is so great that you can find a guide on the ubuntu forums or anywhere else to do anything you want.
Ubuntu is good. I'd also suggest Fedora as it is getting very GUI-based and much less dependent on commands.
I wouldnt recommend linux if you dont have alot of time to put into it.
XP should do you just fine, just share some folders and you can use the built in windows backup software (go to run and type ntbackup and click go)
It isnt much but its fairly easy to use.
Have fun
