Home network setup recommendations?
Supercharged_Z06
So, I’m going to be building and moving to a new house later this year (2 story, fairly modest ~2000sqft) and I’d like to wire it up so that it’s properly networked for home automation/sensors, use of a NAS, internet, home security cameras, etc.
As to current equipment in use/on hand:
2 PCs, both 2.5GbE capable
Netgear nighthawk (RS700s) Wifi 7 router
Qnap TS-469Pro NAS
Cheap 8 Port 2.5G Managed Switch with 10G SFP+ Slot, 8 x 2.5Gigabit Ethernet Ports (Yulinca)
Right now, I plan to wire up at least 2.5GbE to all stationary house PCs and perhaps upgrade my NAS to 2.5GbE as well or at least pair bond the one I have to the switch. I figure I am pretty much fully set when it comes to my Wi-Fi needs with the router I have, but to do this right for the rest of the hardwired network(s) I plan to set up, I’m thinking I may need to invest in a better switch, perhaps one with a few more ports.
Should I just stick with 2.5GbE or go for 10GbE? Also for Ethernet cable, any quality Cat6 rated cable should be fine, right? I doubt any runs would be over 100ft.
Looking to future proof things - and allow for some minor expansion headroom, but nothing too crazy. I figure the important bit is laying in all the hardwiring properly as the walls go up - getting runs laid out to specific area/rooms to cover all possible use scenarios.
To do this right, what equipment should I be looking at for a proper home network? If I decide to hard wire security cameras with POE, I reckon they should also be going on a separate network, right?
Without breaking the bank, what all should I be investing in at a minimum to do this right?
10gbe is hella sweet, but not really needed for general purpose client connections. Even 2.5gbe is really nice, 1gbe is usually plenty. Personally I would run at least 2 - 4 cables per room if the walls are all open, theyll pretty reasonably last 20+ years and who knows what youll want to connect by then (it will also definitely still be ethernet :p ). Even just having ports on opposite sides of the room can be really helpful, and definitely use good CAT6/7 cables, it seems like you know but keep in mind that 6 is only rated for 10gbe up to 30m/100ft, CAT7 is rated for 10gbe at the full 100m/328ft.
If considering security cameras, make sure to only consider switches that are POE+, you might have a hard time finding a decent camera that runs on standard POE. We even have POE++ cameras at work, but those are big outdoor ones with 4 cameras in one housing. I chose to run all of my security systems on their own isolated hardware and lines, but for home setups theres no reason a simple VLAN segmentation wouldnt be fine, especially if youre using all 2.5gbe+ equipment, should be plenty of bandwidth. Also definitely consider getting a good UPS, APC makes nice reliable units that you can trust (at least I do). Youre going to want that especially for your NAS, that way the drives dont crash every time the power blips, plus youll want to shut it down gracefully if the power ever does go out for real.
If you do get a new switch I recommend HP/Aruba, maybe not the cheapest option but they last absolutely forever and are the easiest to configure IMO.
Thanks for the inputs. Yup, I have a couple of good UPS units already, one covering the cable modem/router/switch and the other the NAS and home automation PC (N100).
I'll definitely go CAT7 on the cabling and ensure lots of inter-room connectivity. While 10GbE would be nice, it seems like a crazy amount of overkill, so I think I'll stick to 2.5GbE. As long as CAT7 is there, can always upgrade to 10GbE if needed down the road.
Yup, I plan on separate router/network for POE+ and the security cameras.
For a switch upgrade, what model of HP/Aruba should I be considering?
tbh its going to be hard to compete with the affordability of your current 2.5g switch. I can personally attest that the HP/Aruba 2530 is cheap as dirt on ebay and will do everything you need as far as your POE/Security stuff, we have units that have been running nearly 24/7 for over 10 years. The 2930 is basically the same switch but with 10gbe expansion options and L3 capability, its way more expensive and more than you need, but thats what I personally use as my core switch/router at home. You could use your existing 2.5gb switch as your core, run your main lines off of that, and use a larger/cheaper switch to handle all the extras. Aruba may have cheaper options with their CX/instant line of switches, but ive tried those and I personally dont like them. The config is as arbitrary and insane as a cisco without any of the clout that comes with buying a cisco.
You want to run drops from all the rooms to a single location, preferably near where your utilities enter. Think about running multiple conduits to the outside for utility entrances, in case wiring changes in the future.
If you want overkill, run two lines to two walls in every room, and to the middle of the ceiling as well. If you want to put enterprise ceiling access points, it will be handy. The larger the room, the more important having jacks on opposite walls is, cause maybe you think the desk will be here, but decide you like it there later.
Terminate all the lines at a patch panel, and use keystone jacks on the other end. If you might do antenna or cable tv, add a coax run to every room where you think you (or future owners) might want a tv. You may want a coax patch panel, and to wire for a possible antenna in the attic or on the roof. It doesn't cost a lot to have a coax (and a spare) running to the attic and the eaves, even if you never end up with an antenna.
I don't know if you really need cat7, but whatever cat you get, get matching keystone jacks and patch panel. You probably won't use all the jacks, so your existing switch is probably fine. For the record, cable ratings are for the specified distance and most of that in dense conduit. Your runs will typically branch out pretty close to the patch panel, so most of the run won't be in dense conduit, which means things will likely work better than expected. I have cat5e in my walls, and manage 10G over that on the couple of 10g ports I have. Cat7 looks extra fiddly with all the foil, and you probably won't need it.
Don't be a jerk and label the patch panel and fuses 'room 1, room 2' as if someone will know how you numbered the rooms (unless you put up a floor plan there), call them by cardinal directions or something.
Consider putting in wires for surround sound in the designated tv room. Wall jacks for side/rear speakers are handy, or you could put in-wall speakers. If it's not going to be a good shape for that, in ceiling speakers work too. Could do both and do Atmos, too, if you really want, but as someone with a 7.1.4 room, 5.1/3.1.2 (or 4.1/2.1.2) if you don't have a place for a center) is pretty close, and 6 extra channels means a more expensive receiver.
Some great suggestions already. We had our parents custom house wired up back in 1995 and today the wire runs gigabit no problem and probably can even do 2.5Gb but I haven't tested it yet. So some lessons from that experience:
  • I totally agree with the 2-4x runs per room and the opposite wall suggestion, even when you think you have enough ports, you will need more.
  • Do hard wired runs for every possible device in every possible location (NAS, camera, access points, doorbells, etc). Running some wire and leaving in a box is far, far cheaper than having to run one later.
  • Do multiple runs to every location. Because if someone else is doing it, they WILL run one wrong or break it and you won't know until down the road. With 2x runs, you have a good chance the second one will still work.
  • Don't forget multiple runs of coax. Coax is great for a lot of different type of signals and can be used to put your modem where you want it or run a 2.5Gb moca backbone for something you want to keep physically isolated from ethernet. I've found all sorts of uses for our coax runs (dual rg6 to each room). They can also work as a backup to the ethernet in the event it's completely cut after the walls are up.
  • Don't forget the garage, the pool, the gazebo, whatever else you have on your property--having wired connections everywhere makes possibilities endless. And we don't know what the future holds yet so having wiring everywhere makes the future easier.
  • Run some pre-termianted fibre between floors if you can. This will give you almost infinite capability for the future for ridiculous bandwidth like 40Gb or 100Gb.
  • Use the very best wire you can get, and make sure it isn't fake! We used some 400Mhz rated wire back in 1995 that was 2x as much as the next most expensive. I think it's what made it easier for us to have iperfs that are 900Mbs+ between rooms on what is literally 30 year old wire now. Be sure the wire is branded and from a reputable retailer that has brick and mortor stores like Grainger. Why? Because it's easy to sell fake wire to customers you'll never see angry in your face. Amazon and other marketplaces are an absolute no-no for the wire--fakes galore, and fakes so good you'll never know are fake until they fail. For the $200-300 you could save on wire, it's not worth it.
  • More than likely there will be some electrician that supposedly knows how to run ethernet. If you can afford to do so, run the wire yourself. This way you'll know it's a job done right and you can also photograph it so you know where all the wire is. And it's not hard--my brother and I ran all the coax and telephone for our hotel expansion back in the early 1990s when I was 15 and he was 11. :eek::eek: And run the wire just into boxes and keep a nice long service loop there so when you come back and terminate it later it will be easier. DO NOT UNDER ANY CIRCUMSTANCES LET AN ELECTRICIAN TERMINATE THE WIRE!! It's been 30 years and they still don't know how to terminate ethernet properly or to spec. I still have the entire upstairs at my parents house to re-terminate because they left 3" untwisted wire on all those outlets. Nothing like spending good money for people to make a mess for you. Save the trouble, buy the tools and do it yourself. You'll save money and a lot of grief.
  • If you want to contract out the wiring use a 'structured wiring' company who normally does business or industrial ethernet. This will be a small job for them so they might not even take it or it might be 2x more expensive than 'electricians', but it will be done right. If you do use such a company, check each port using iperf between two of your 2.5Gb systems to confirm all the bandwidth is there.
  • 10Gb is here and is cheaper than 2.5Gb--on the client side. Dual port 10Gb nics are $15 shipped on ebay today. While these cheaper cards are typically not NBase-T (2.5/5 capable), you can use them really well for point to point connections between devices (like a computer near the nas unit), and for accessing two networks simultaneously (like the security camera network and the main lan). The other benefit is as 10Gb switches fall in price, you can simply swap out a switch or add a small 10Gb switch where you need 10Gb bandwidth between destinations. You can also use them in 1Gb mode along with the 2.5Gb for additional smb3 bandwidth.
And don't forget pull cords for the conduits between floors. And make those conduits big enough to hold say 2X the number and type of cables you anticipate using. Yourself from 2045 will thank you for that.
I wish, wish hard at times, :notworthy: :cry: that when we did a second story addition back in the day, I had asked the architect to design in conduit. So between floors, I have to be satisfied with fast wifi backhaul (between mesh routers) instead of Ethernet.
I am going to do the rare thing and disagree with you here. If you contract out the wiring install to a professional installer and they did not supply you with a LinkIQ report for every single drop then you did not hire a professional structured wiring installer. There is a hell of lot more to a correct cable install than iperf will ever tell you. Just because you bought good cable and connectors doesn't mean the finished the installed product meets the standard you expect. A LinkIQ report will let you know if it does. If you're hiring the job out you need to establish up front that the installer will supply a report that covers every drop. Frankly, if you're doing it yourself go rent a Fluke and figure out how to use it.
PS: OP I said I wasn't going to say anything but ..... For the love of fuck don't install CAT7. It was a bastard thing that is deader than dead and never really was a thing. I know most of you live in the world of it's bigger so it must be better but FFS educate yourself. CAT6A
Setting up a home network can be both exciting and overwhelming, especially with so many options available these days. A few thoughts based on my experience:
  1. Router Choice: If you're looking for reliability and performance, I’ve had great success with Ubiquiti's UniFi Dream Machine (UDM) or the AmpliFi series. They’re a bit more prosumer-grade but offer excellent control and stability. For something more budget-friendly, ASUS routers with Merlin firmware are solid choices.
  2. Mesh vs. Wired Backhaul: If you can run Ethernet, definitely go for a wired backhaul with access points (APs). It’s a game-changer for stability and speed. If wiring isn’t an option, a good mesh system like Eero or Orbi can still deliver great coverage, but prioritize tri-band systems to minimize performance loss.
  3. VLANs and Segmentation: If you’re into tinkering or have IoT devices, setting up VLANs to separate traffic (e.g., IoT, guest, and main networks) is worth the effort. It adds a layer of security and keeps your network organized. I recomend also telus customer service for fast internet.
  4. Future-Proofing: Consider Cat6 or Cat6a for wiring if you’re running cables. It’s overkill for most homes right now, but it’ll save you headaches down the road if you ever upgrade to 10GbE.
  5. NAS/Server: If you’re thinking about a NAS, Synology is user-friendly and powerful for most home users. Pair it with a UPS for peace of mind during power outages.
A lot of good advice here...
Back in 2009 when I moved in here, we did some remodeling in several room to get rid of a lot of the 1970s fake wood paneling in the basement. That gave access to just about every room upstairs.
I ran A LOT of cat 5e. Most rooms have maybe one to two drops per wall. And yes, I ran two cables each time...never know when a staple is going to get one.
Here it is 16 years later and I'm running 10gbe on that cat 5e.
Advice I've heard and nodded....run a big enough conduit between the hard places to chase future cables. In the past year I put up cameras and did have to run some new cables. A few chase ways came in handy and I wish I had another from the mechanical room in the basement to the attic.
Another is wire for speakers. And not just for the tv. Think about if you may want some home audio in places. Speaker wire is cheap.
Qnap TS-469Pro NAS
CAT 6a shieled (outer shield or fully shielded twisted pairs) will work as the bare minimum, even though cat 7 and cat 8 are around the same price now these days. I have CAT 8 which was left overs from wiring a place, but I will tell you his, its a pain to work with compared to shielded 6a crimping ends on them. But since they pre make cables, I would pull those but I would get some that is outdoor rated since cmx jacket is fireproof. Plenum is indoor cable inside air ducts and is not flame proof.
As far as your network, I would use just the 10gb port on the router, then a MikroTik (CRS304-4XG-IN) (4 port base-t 10Gb) then chain as many needed TRENDnet TEG-5762 switches then get a 10G base-t SPF module and use the current switch on the end of the 2.5Gb network. Install a 10Gb interface into the NAS and run it to the micritik switch.
As far as the cameras, I would use a cameras + NVR and run a seperate network from the back of the NVR on the camera inputs. Wireless cameras are horrible unless you are in a secluded area, they pick up noise and video drops frames in a lot of suburban areas. Avoid them if you can. I have a doorbell cam that I wish was POE because of its fuzzy picture compared to the wired cameras. For wireless cameras like the doorbell, you have to use an app to set it up, so I took a wifi router, put it in access point mode, connected to my real network so I can use the app to set it up, then I disconnected the access point and plugged it into the NVR. Since it was DHCP in the camera and the camera inputs of the NVR has its own dhcp all I had to do is scan for the camera and add it using the password I set when I had it connected to the phone app on the network. Then if I want to use the phone app, I have a tablet with that app running on it in my back room that I use the app, You don't want to run the cameras within the network even by vlan because it will slow down the network, so always use a wire patch that goes back to the NVR, Most IP camera NVRs have a POE switch in the back so you can run multiple POE cameras off the same camera port using a POE switch, So the Camera Cat5 don't have to be home runs. Most IP cameras are 100Mb so unless you are installing high end cameras cat 5 will work, even though I like using cat 5e CMX foam core because it doesn't kink or twist on itself. In attics, I like to use the zip ties that have a screw mount. Externally, I like to use flat plastic conduit that I screw down (never trust the sticky tape).
Edit: Also with ethernet cable running from floor to floor, either use CMX which is flameproof with screw mount zip ties , or CMR which is called riser cable in a conduit.
When we did a remodel back in 1990, I did NOT run Ethernet between the first and second floors. Nor did I have the contractor install any conduit. I have regretted that ever since. On a new custom build or a remodel, spend just a bit extra for future-proofing. As for the conduit you can search online to find recommendations for capacity of different size pipes. Add at least 1/4" to the recommendations, and that's after you double the anticipated number of cables. Your 20-year older self will thank you profusely. Me, my 35 year older self is pissed.
Conduit is good. My house was built with all the electrical wiring in conduit. I had it rewired before I moved in. It was the old cloth covered stuff. It's much cheaper and less of a mess than tearing wall open. Same goes for network cabling, except the cable spec changes more often. Electrical wiring from the 1990s is still pretty new. Cat 5 (meaning not 5e) would have gotten really annoying a long time ago.
10Gb isn't a problem in most houses as long as you've got the right number of wires. It'll run on Cat5e, you just don't get as much cable length as with 6a and better.
If I were building personally I'd put in conduit and run both Cat8 and multimode fiber. Of course I'm already using fiber. What I would have to think about is if I wanted to bother installing coaxial. Around here Comcast seems to be moving towards making it obsolete. They're switching cable TV subscribers to IP TV.
Knob and tube? Mounted on glass supports? That's real old.
I have coax installed, and I get a good signal to the far end of my house on the second floor.
Where is "around here?"
Sheesh I hope not. Not until Wi-Fi speeds are way faster than now. Considering where my upstairs TV is, IP TV would be a disaster, especially at 4K or more.
Lots of great tips from everyone, thanks!
Going to make sure I run some conduit between floors dedicated to when/if I might ever need to run something between a floor or up from the basement utility closet to the attic.
Since this is an all new house build, I have the luxury now of also putting all the backbone wiring in that I think I might ever need. It's not a huge house (2 story and full finished basement, roughly 2600sq ft.) I'm going to run about 3500ft of Cat6a pretty much *everywhere*. Also 750ft of audio cable, and 1000ft of alarm wire, and a couple of 50ft fiber HDMI 2.1b runs so that I can feed a couple large screen TV's with both audio/video remotely (i.e. a PC/Plex server)
Sticking with my 2.5Gbe switch for the primary network for now, but also adding an extra POE switch to handle sensors I am placing around the house. Also a complete second network dedicated solely to cameras/security that'll be driven by a POE Reolink switch. Went with Reolink for the NVR and all security cameras as I like their HA integration, features offered, and great bang for the buck they offer.
Will eventually upgrade the main network to a nice 10Gbe switch down they road which Cat6a will have no issues with, but for now, 2.5Gbe seems fine.
Running and terminating everything myself, so I'll know it is done right. 👍
a couple of 50ft fiber HDMI 2.1 runs so the I can feed a couple large screen TV's
I would put those in conduit too, assuming the runs are tricky, because all runs in a modern house are tricky. Dead HDMI cables feel more likely than dead twisted pair copper.
The HDMI runs I am putting in for the 2 big screen TVs will be armored fiber with detachable HDMI plug modules at both ends that are replaceable/upgradable:
https://www.amazon.com/dp/B0DPWRQVHZ (Edit: Had the wrong link to the DisplayPort version, corrected it to reflect the HDMI version)
May just put keystones in these to further protect the fiber run and use short extensions to handle any wear and tear.
However, if something were to happen to a cable (unlikely) or I want to run something else (more likely), laying some conduit and a pull cord is good insurance and a lot easier than having to rip dry wall up.
If you go the route of conduit, use the gray PVC that's at least 2" and not that blue 'smurf' tubing with all the ridges for cables to snag on. We did both in our hotel installs at one point and only the 2" PVC was painless and easy to work with.
No disagreement from me! This wasn't a common thing back in 1995, but am so glad it's standard now--absolutely get LinkIQ reports and if they don't offer them, skip it! Thank you for bringing this up as it gives me more knowledge for any future installs I run into. (y)
...I would get some that is outdoor rated since cmx jacket is fireproof. Plenum is indoor cable inside air ducts and is not flame proof.
Great tips on the cabling! A lot of code now has flame retardant requirements.
The Moca standard is looking towards 10Gb and beyond and I personally find coax a lot more 'durable' when dealing with contractors and whatnot, so with such a minimal cost of materials and almost zero additional labor, I'd put it in a new install. It's still going to be around as many older homes will still have only coax as time marches on.
Since this is an all new house build, I have the luxury now of also putting all the backbone wiring in that I think I might ever need. It's not a huge house (2 story and full finished basement, roughly 2600sq ft.) I'm going to run about 3500ft of Cat6a pretty much *everywhere*. Also 750ft of audio cable, and 1000ft of alarm wire, and a couple of 50ft fiber HDMI 2.1 runs so the I can feed a couple large screen TV's
Sticking with 2.5gbe switch for primary network, but also adding an extra POE switch for sensors I am placing around the house. Also a complete second network dedicated just for cameras/security that'll be driven by a POE Reolink switch. (Went with Reolink for the NVR and all security cameras as I like their HA integration and the features and price of their cameras).
Will eventually upgrade the main network to a nice 10Gbe switch, but for now, 2.5Gbe seems fine.
Running and terminating everything myself, so I know it will be done right. 👍
Great point about the alarm wiring--people don't think of this enough! Wireless alarm sensors are just as easy to defeat as wireless cameras with a jammer. Hard wire every door and window and glass break, fire, etc. sensor that you can. And double up on runs there too as a run may fail over time--we have had some wire failures over time at my parent's house and it's annoying to know that certain sensors are now wireless.
https://www.amazon.com/dp/B0FN7QWF8K
Hmmmm...are there any more reputable companies making a product like this? This looks like one of those chinesium somethings that's going to fail/get buggy in a year. If there's other more reputable companies making something like this, then with the conduit it's easy to swap it out. Otherwise, conduit would help you get this stuff out and put in a different solution (industrial HDMI over ethernet or fibre, etc.).
Well, this is a fully optic cable solution as far as the main cable run is concerned and at a price point that seems reasonable for what it is. (Snagged a couple of them during the Black Friday sale this week @ $106 a pop for the 50' length cable.) It appears it's fully HDMI 2.1b compliant, will pass 48Gbps for uncompressed 8K@60 and 4K@120Mhz, and supports CEC/eARC without issue. At least the reviews for it look pretty damn good. Going to test it out, and if it passes muster, going to keep and use it. I like that it uses standard OPM connectors for the fiber cable. Being an optical cable, there's no electrical/copper transmission going through it, so no chance of electrical/magnetic interference. Bandwidth on that type of OM3/OM4 fiber cable easily supports 100+Gbs, so it also seems pretty future proof... once HDMI 2.2 or higher hits, it's just a simple plug upgrade/swap. If one of the cable end units happens to fail a year or two down the road, I can simply buy new end connectors. And I like that I can hook up the main cable and terminate it via keystone jacks and then feed short extensions to any equipment I may want to hook to it.
Yup - want to completely avoid the use of any and all wireless sensors wherever possible - just go fully hardwired. Way easier to do when the house is being built, but much harder if retro-fitting/installing into an existing home. Going to run individual lines for each and every door/window from where my main alarm panel will reside - can then zone some of them later on if desired, but that will give me full control over how exactly how I use each and every sensor. And no worries, going to label the hell out of each and every wire! :D
Sounds good on paper and as along as the actual fibre cable is good, sounds like the rest could be swapped out if it fails. I'd still almost absolutely run conduit for this as replacing it afterwards sounds like it would be tearing up sheetrock.
Sweet! Yeah, the labelling is something that all the people that worked on my parents home did--but to their own logic. :confused: I wish we would have just told them to use the numbers assigned to the rooms (if we even did that? Need to check the original plans).
I also I picked this up:
https://www.amazon.com/Klein-Tools-VDV501-851-Ethernet-Locator/dp/B085LPN71C
Along with their tone inserter/probe:
https://www.amazon.com/Klein-Tools-VDV500-123-Replaceable-Non-Metallic/dp/B07ZWCM8L5
So, even if labeling goes missing or gets damaged somehow, I should have no problems sorting things out during wiring or anytime thereafter.
Nice! Definitely let us know how those tools do the job. :) I haven't had a chance to play with any of the newer stuff in the last decade or so.
