I found out that some of the phone jacks in my home are actually cat5, and I want to use them for ethernet for HTPC media center extenders.
I have my router in the office, and there's a cat5 cable that goes from the office to the garage, where all the other cat5 cables go. I bought some wall jacks and keystones from monoprice and the punchdown tool and whatnot, and got that working.
So I bought a gigabit switch (D-Link DSG-1005G) to go in the garage, but it didn't work. It didn't even detect anything. I thought maybe I had done the punchdown or crimping wrong, but if I put two laptops on either ends of the long cat5 runs, and do an iperf test, I get solid 100Mbps both ways (duplexed).
I was disappointed that I couldn't get gigabit speeds, but I suppose that only works for short cat5 cables.
So I figured maybe the switch was a problem, so I got a Netgear 10/100 switch (FS105) and that seemed to work. It would actually detect a computer on the other end of the long run. But when I did an iperf test, plugging a laptop directly into the switch, then another laptop at the end of the long run to the office, I did get full 100Mbps one way, but not duplexed. The other way was really slow.
And when I plug another room into the switch (ethernet over two long runs, with switch in the middle), I get terrible speeds, like 50Kbps. It gets really sketchy.
Do I need a better switch, or is there too much attenuation/crosstalk on the runs?
If I just do iperf test between two laptops going directly over just 1 long run, I get full 100Mbps duplexed. It isn't too much attenuation for the laptops, how come the switch fails?
