I wish to change my current setup to a beefy future proof (~4-5 years) virtualization workstation,
and would like some advice for which parts would best fit my needs, especially in terms of CPU and motherboard.
Basic computer usage: web browsing, office work, light picture editing, etc.
Light gaming, mainly indie games and flash games. Nothing heavy or fancy.
(I plan on using an IOMMU to pass a video card to Windows guests for gaming, so this CPU feature is a must.)
Multiplatform software development and testing
Various virtualized servers and OS test environments
3000$ before taxes and shipping
3) Which country do you live in? If the U.S, please tell us the state and city if possible
Canada
CPU(s) (+ CPU Cooler(s))
RAM
Video card(s)
Motherboard
PSU
Case
Sound card (if necessary)
I'll re-use all my old hard drives:
- Crucial RealSSD C300
- Samsung HD502HJ
- Seagate Barracuda ST3250310AS
- Hitachi HTS54502
Aswell as my DVD drive:
- Asus DRW-24B1ST
I also have speakers, keyboard, mouse, etc.
6) Will you be overclocking?
No
Asus VH236H Full HD (1080x1920) 23"
LG L1752T (1280x1024) 17"
In 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Server-grade, and if possible VMware certified
Intel gigabit LAN chips
Multiple PCIE 16x slots
Onboard video (the minimum is enough, as its just to support a VGA console)
At least 6 SATA ports
Internal USB port(s)
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, either
Linux (Gentoo/Arch with 3.1 or 3.2 kernel) 64 bits for Xen or KVM
or VMware ESXi 4/5
I was looking at:
2x AMD Opteron 6200s CPUs (not sure exactly which one),
Supermicro barebone (4022G-6F) to cover motherboard, case, PSU, CPU coolers and fans,
16GB of ECC Reg Kingston RAM (KVR1333D3D4R9S/8GHB x2),
XFX Radeon HD 6670 (XFX HD-667X-ZNFQ) to cover the basic 3D gaming needs, while still using only one case slot,
Creative 7.1 sound card (70SB088000004) for audio since the motherboard doesnt have onboard audio.
Would such a setup be overkill for my needs? What would you suggest?
Thanks for your time
Canada
RAM
Video card(s)
Motherboard
PSU
Case
- Samsung HD502HJ
- Hitachi HTS54502
- Asus DRW-24B1ST
No
In 2 weeks
Yes, either
or VMware ESXi 4/5
I was looking at:
