OSUguy98 said:what's your CPU?
Is the protien a "p2102_lambda_5way_melt_0_00000"? that's the only 414point protein I see on Stanford's Protien summary page.... It's a Gb Gromac... could take awhile depending on the CPU..... I don't think I've folded any of those yet....... I'll check when I get home
Keep on Folding!! For the [H]orde!!
joeb0b said:Yeah I got a couple too. My P4 3.6 is doing 1% every 41 minutes. My 3.2 is doing the same in 45 minutes. This is about 6.05 pph and 5.52 pph respectively. EMIII doesn't even know what it is. Is there a way to update EMIII with new wu project types?
-joeb0b
pageian said:Approx. 63 minutes a frame on an Athlon XP 2.1 GHz.
meisterbrau said:I got one of the 414 pointers today also. protein 1258 - p2102_lambda_5way_melt_0_00000
It's taking 37:20 per frame on one core of my dual 3800 (oc'd to 2.5g).
By comparison, the other core is running a 586 pointer, which is only taking 26:25 per frame. (protein 920 - p2364_Protein_A_wt_Sosnick).
Doesn't seem right.
meisterbrau
Imitation said:Hmm I woulda thought the 3800 core at 2.5 would be doing better than 37:20. My Opty at 2.63 is doing them in 33 flat. Wonder if the cache is effecting it at all?
meisterbrau said:I was doing some other things with my machine at the time (like reading this forum), so it wasn't a pure test. (btw, these new forum ads do seem to up the cpu usage for opera quite a bit). When I stop the non-folding activity I cut about a minute off of the times for both cores, so the lambda protein is coming in around 36 and change. That still sounds a tad slower than the frequency difference would explain I think, so maybe the cache does make a difference. I'm also not running my system memory at 1:1 in order to overclock it, but I've been told that wouldn't make much of a difference with AMDs.
meisterbrau
sandmanx said:http://www.em-dc.com/
Click on downloads, and grab the latest data file. Follow the instructions on the page.
Killer[MoB] said:You may want to check on this box. That's a pretty good bit slower than it should be.
I'm getting 00:52:50 to 00:53:05 on a XP @ 1733.
pageian said:I saw that and took a look, it's my work box so it's constantly in use but still should be getting most of the cpu. I checked the cpu usage yesterday and it was getting approx. 99%, checked again today after updating Firefox to 1.5.1 and it's about 80% with Firefox taking up most of the rest.What the hell? Between the memory usage and now this I might have to switch to Opera.
pageian said:Yeah, Firefox seems to use quite a bit more resources than some others though..... maybe it's not a good browser to use on a folder. Something to think about anyway.
