holy crap!
deadm3at
my box is running a WU worth 238 points, complete insanity!
it says a p697_L939_WT_Raleigh protien 397
anyone else get one of theese puppies? each frame takes only like ~8 min on my p4 2.8
should see a spike in team scores if lots of people got em :)
All tinker wu's have been balanced with gromacs since Stanford switched its points benchmarking machine from a celeron 500 to a P4 2.8.
There may be soem variation by project where certain tinker are worth more than gromacs and vice versa.
Since AMD was always better at tinker than P4, it may be that AMD will see a small boost folding without -advmethods. This needs further study to be verified.
Duron spitfires and Athlon Thunderbirds are not so bad anymore if they can get tinker.
I just got done crunching a Tinker worth 238 points. Too bad the server seems to be down and not taking results at the moment.
I'm also crunching a 128 point tinker. The funny thing is that when I first got the work units, EMIII identified them as normal 70 point Tinkers.
Now that they have the Tinker points "updated" I'd like to get a few more of them. Yeah, just when I get a Gromacs to replace the Tinker I just finished.
Too bad I can't get a Gromacs for my system at work. Damn PIII 700s take forever to crunch the Tinker it's working on. Hopefully it will be done before I die of old age.:D
Try updating your EMIII emprotx file and see if the point values change.
That's 2.22 days work. About 107 points per day. Not bad for a P4 and a tinker.
At first they were identified as 70 point units. A day or so later I looked at EMIII again and they had their values changed. Didn't have to do anything and got the change. I don't think I did an EMIII upgrade so I don't think that was it. I'm not complaining. The work is getting done and it's correctly reading the points so it's all good.
