Holes in Plexi
magoo
I want to put a couple of holes in the window of my Corsair 800D.
I've done this before with a hole saw, but I left a big burr on the back side.
The hole just wasn't clean enough for me.
Now I can have the thing done professionally, but I'll have to send the plexi out, etc.
Is there anything else I can use/do to make this look better than the plain old low speed hole saw??
How big holes are we talking? A few mm across, or like 5 cm?
I have both drilled holes in plexi and used an electric saw to make 120mm holes. For the sawing I used a blade meant for plywood. I taped the area with paint tape and it worked out alright. But I advice you to clamp the plexi to a piece of wood, so you have something to guide the blade, and the plexi won't snap.
Hope that made some sense.
Or you could use one of these: (the link is from a danish site, but you get the idea)
http://www.carl-ras.dk/e-shop/bitsboroghulsave/hulsave/cirkelskaerer/cirkelskaererhss36-140mm/
put masking tape on both sides and a piece of wood on front and back. Clamp and drill it should give you a clean hole.
I think you need a rotozip. Google rotozip and plexiglass. People seem to have good results.
I would just buy another plexiglass panel from homedepot and try again.
Oh shit.............I forgot...........
What I am doing is making 120mm fan holes and the necesary small holes for the fan attachment.
I have a 4 inch hole saw.
I have a good variable speed drill and a Dremmel.
If you clamp wood to the backside of the plexi, that should reduce burring.
You can also use a sharp knife to get any left over burring.
