D
Deleted member 89137
Guest
i read the faq already, where can i buy a holesaw? and how much do they cost...
speedracer089 said:this a a arbor it goes in the center to start and guide the hole
http://www.toolsforless.com/milwaukee/images/49-56-7010.jpg
what do you mean you dont have the arbor/mandrel.. you NEED it to cut... its the drill bit that drills a pilot hole to keep it steady... unless you somehow took a cupsaw without the mandrel and duct taped it onto your drill in a way that its totally even and wont budge and you drill it really wellDudeItsMe said:That's about what I have Wayne, but it doesn't have an arbor/mandrel. Oh well, I already cut the holes. I'll figure it out next time.
elite.mafia said:now will a holesawcut through clear acrylic/plastic? oh and alluminum
i recommend the bi-metal ones for cutting metal... dont go cheap and get wood blades tho... ive tried that and it ground up the teeth and wasnt sharp anymore... now i got a hole in my psu with a round shiny grinded circle around itelite.mafia said:now will a holesawcut through clear acrylic/plastic? oh and alluminum
I mean that I said, "F*** this, this holesaw must just suck, I'm using my dremel, and I dremeled my holes. I would give the dremel holes a 7/10 rating. They look fine with the grills on though. Maybe I'll put tornados behind them to keep anyone from looking at my case too closely...wayne said:what do you mean you dont have the arbor/mandrel.. you NEED it to cut... its the drill bit that drills a pilot hole to keep it steady... unless you somehow took a cupsaw without the mandrel and duct taped it onto your drill in a way that its totally even and wont budge and you drill it really well![]()
20??... crap, im a bit late then... i didnt recommend homedepot, i doubt i even mentioned it... altho i did buy mine there.. BIG RIPOFF THO... but at that time i didnt kno where else to get cheaperQtip42 said:!!!!!!!!!!!!!!!!
dammit people.
If you spend more than $20 on a SET of hole saws up to 6" in size you are getting ripped off.
Stop recommending home depot.
Harborfreight.com (either locally or online) has the sets for cheap as dirt. Nobody here doing basic modding needs anything better. I've cut through 1/4" aluminum with these........they're so cheap who cares if you dull the crap out of them. Mine however are still in great shape.
what do you mean it gets jammed?.. like it gets overtightened and its stuck?Vulcanus said:also, you might want a pair of pliers handy cause my arbor always gets fuckin jammed in the holesaw.
EDIT: does harbor freight have large holesaws or only the <3" ones?
not <3, less than 3"wayne said:what do you mean it gets jammed?.. like it gets overtightened and its stuck?
<3.. heart ones?
i dont have prongsVulcanus said:not <3, less than 3"
And yeah, the arbor I have has the ring you pull down with the two "prongs" on it that just snap up and are supposed to keep the holesaw from not tightening down. Well the prongs find a way to pop out and the holesaw overtightens WAY too much before I notice it and I have to get a wrench/vice/whatever to break it loose.
