wee96 said:Ive never gone above 310, not due to failure but just do to not having the need.
kirbyrj said:How did you get your memory to run at 350mhz? That's insane.
What timings did you have to use to get it to that speed?Bona Fide said:It's TCCD...I remember Eclipse showed me a DDR700 kit a little while ago. I guess TCCD can really go up there.
SKy042 said:What timings did you have to use to get it to that speed?
thunderstruck! said:465HTT on the Expert
Didn't you have a 2.7 at some point in time?HmmmDonut said:$70 board
Which board is that?HmmmDonut said:$70 board
Thanks, xp90c is what I'm using.LongShotHero said:wow that's a pretty awesome OC...Especially if you are using the xp90c in your sig...I hit 330 with my board when I was testing it but I've never had my processor clocked high enough to need it.
contaminant said:Didn't you have a 2.7 at some point in time?
Anyway, I don't think I've ever gone past 350, not because I can't but because I've never really tried.
contaminant said:Yeah I remember now, you were using 300 HTT to reach 2.7GHz IIRC.
hehehe, are you suggesting a highest bandwidth contest?gjwild said:May be a bit off topic, but I posted a thread in another forum hoping to see some high HTT's combined w/ some SiSoft memory marks but no replies.
I bet (cf)Eclipse could start a thread on this topic (hint) in this forum and we would see some results..
Yes I am(cf)Eclipse said:hehehe, are you suggesting a highest bandwidth contest?
check the memory forum in about 10 mingjwild said:Yes I am
It has been a long time since I have seen any results from anyone!
