High Temps
Sparky
Thunderstorm was in the area so I shut my system down for the night.
Next day I started it up and noticed high temps on my CPU 100c). I then checked the fan and water pump rpm's and they were fine. Next day I cleaned out the case, filter and radiator and the old thermal paste and installed new. Started up and same high temps with normal rpm's.
I am going to try to find a new AIO and order it.
You don't mention what cooler you are using, but I had similar issues with a Corsair H110i GTX.
Those things apparently had 5 years of warranty, so I got it replaced under RMA.
cooler master Seidon 120V
which replaced a corsair H80i which failed under warranty but could not be replace because they dont make it anymore so I got cash instead.
I cant seem to find it anywhere to purchase
The problem is that only 2 AIO's will fit and work in my itx case.
I found an H80i and ordered it only to return it as it was a V2 which has a thicker radiator and wont fit. The listing mentioned nothing about a version 2.
