andrew911tt
- Apr 13, 2005
For Monitors with high resolutions like the Apple Cinema 30 Dell 2405FPW and the soon to come Dell 3007FPW
1) Do you have to use a single DVI connection or 2 DVI connections or will a D-sub take advantage of the 1920x1200 or 2560x1600 resolutions?
2) To make the use of these resolutions for 3ds-max and auto-cad ect. Do you need to use a good video card (7800gt), Workstation video card (Fire GL), or will a basic card (x300) be able to do it?
3) If you do duel monitor set up like two 2405s do any of the answers change?
4) Do any games support resolutions that high?
5) For moniters like the IBM T221 what do you have to do to get the res of 3840x2400?
Thank you
Thank you
