High-Frequency Self-Aligned Graphene Transistors
HardOCP News
[H] News
Did that just say "record-high cutoff frequency up to 427 GHz?" :eek: Thanks to Jeffery Struss for the link.
A self-aligned process, enabled by the unique structure of the transferred gate stacks, is then used to position precisely the source and drain electrodes with minimized access resistance or parasitic capacitance. This process has therefore enabled scalable fabrication of self-aligned graphene transistors with unprecedented performance including a up to 427 GHz.
Graphene is, so exciting. Hell, nanotech is exciting in it's own. Can't wait to see more!
This along with the Higgs Field (LHC in Geneva) announcement this week makes 2 major wins for science. Virtual reality here we come!!! :D
Obligatory "But can it run Crysis" post. /s ;)
Yea, at about 6,000 FPS. heh, assuming you'd get something like a SNB-E + Kepler at 100x Ghz. Personally, I'd like to be excited, it just seems we've been hearing about this stuff for 10 years, and we're still at 3.x Ghz with silicon. Can't wait till we do though.
... but how fast does it run when there are billions of graphene transistors? You can't make a CPU/GPU/flash with one solitary transistor.
As if NPC AI counts in a multiplayer deathmatch :D
picmip 5 is all I need but those jiggahertz chips would draw a lot of frames
I'll be excited in 30 years when it finally comes to the consumer market!
2 years ago we were making transistors from this stuff at 25 ghz. I'm not sure if anything's come of it yet. It doesn't look like it's funneling into the chip-world yet.
Also there was this from 6 years ago:
http://www.sciencedaily.com/releases/2006/12/061212091344.htm
There's been a lot of a progress within the last 1-2yrs.
http://phys.org/news/2012-04-uwm-discovery-advances-graphene-based-electronics.html
http://phys.org/news/2012-05-graphene-boron-nitride-breakthrough-microchip.html
Research on applications for graphene aren't limited just to transistors. While that's the most well-known, and to some exciting, aspect of graphene it's only one part of the whole. Research with graphene ranges from batteries, solar cells, optoelectronics, making non-toxic rust-proof steel, water desalination, and many others.
As such there's not as much effort going into researching graphene based electronics as many assume. Even so, the progress being made puts graphene based semi-conductors something we can be certain is part of our near-future.
That's nice but still nowhere near a practical application. GaAs can reach hundreds of GHz too.
Based on its ability to deal with heat and insulate against electrical leakage by a factor of something like 100 times as well as Silicon?
The problem is mass production. Once that is solved , a truly incredible generation of CPU's will come forth.
I would imagine that with graphene in the picture we just bought ourselves another 15+ years of Moore's Law.
